Oil Seals.
   / Oil Seals. #1
John47
Missouri Ozarks.
Yanmar FX235
Anyone know how oil seals are measured??? I am changing the seals and bearings out on a trailer, bearing numbers I've managed to get. Seal OD is 52mm but I don't know how the ID is measured, shaft size where seal seats is 31 mm.
   / Oil Seals. #2
The measurements you need are the diameter of the hole the seal fits in and the diameter of the shaft it is going over. Take you measurements with a good set of calipers.
   / Oil Seals.
The old seal is "shot" so no chance of a reliable measurement of the Inner Diam.
Shaft size is 31mm as already stated.
Would a 25mm ID be too small?? 28 be too big? I'm ashamed to admit this, but I have fitted many thousands of oil seals years ago and damned if I can recall how we measured them!
   / Oil Seals. #4
John, sounds like you're trying to second guess the method of sizing the interference fit between radial seals and the shaft. The fluid seal industry has already done this for you, so the shaft O.D. size is all you need. Just make sure you get a radial lip seal with a garter spring cuz they last twice as long as seals without. Also, don't forget to call out the width of the seal too.
Bill
   / Oil Seals.
Bill
Thanks Bill, thats what I'm after, looks like the seal size I need to order is a 30mm X 52mm X 7mm wide
One thing I always do, is log the part numbers down in a file after I've done my repairs!!
   / Oil Seals. #6
well close, if your shaft is 31 mm then ya need a 31 mm id not a 30 mm id
   / Oil Seals. #7
Many times, metric seals with have those three numbers on the face of the seal. If you don't have any luck finding metric seals, I've gotten metric seals from a place called Harwal in New Hampshire. I usually buy the Viton lip seals (expensive, but very good) but they probably have others.
2011 Ford E-350 Passenger Van (A53422)
2011 Ford E-350...
2018 TY-CROP MANUFACTURING LTD DRY BULK PNEUMATIC TRAILER (A53843)
2018 TY-CROP...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2021 CATERPILLAR CB2.7 DBL DRUM ROLLER (A52705)
2021 CATERPILLAR...
2000 Ditch Witch 3700DD Ride-On Trencher (A53421)
2000 Ditch Witch...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
