Buying Advice Oil type for 1954 Dexta
   / Oil type for 1954 Dexta #1
vinaysharma
north augusta, sc
Ford Dexta
3 point lift on my Ford Dexta slowly bleeds off. Had the seal replaced assuming it was bad. Still the same problem. Someone suggested I should use 80 weight oil. Is the right answer? If yes, who sells this special blend? thanks.
   / Oil type for 1954 Dexta #2
a lift that slowly bleeds off when the pump is off is not a huge deal.. if it will hold up a minute or more under load, that's fine for 95% of farm work.
it's possible the cyl bore is not perfect and that's the leak.. or could be thru a check valve or relief, or control valve.
heaveir oil may mask the problem a little bit.. however.. you also risk cavitation in the pump, and a blown pump, unless it was designed to pump heavy oil. for instance.. a ford N with a scotch yoke pump was specifically designed to pump 90w oil. pumps on the newer machines were designed around utf fluids.
sc gets cloder than fl.. gear oil in a hyds system might as well be a lump of grease when it gets cold.. that is not healthy for a hydro pump....
your call.
I don't have a manual for the dexta.. so am just putting some general info out.
most other ford products are specifying a m2c134 spec utf style oil in hyds...
Backhoe Attachment (A50322)
Backhoe Attachment...
UNUSED AGT QK20R EXCAVATOR (A51243)
UNUSED AGT QK20R...
2015 Cadillac ATS Sedan (A51694)
2015 Cadillac ATS...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
2015 Z Master Professional 5000 Series Model 74942 60in Zero Turn Mower (A50322)
2015 Z Master...
