ok lets see them pictures of your tractor!
   / ok lets see them pictures of your tractor! #1
travis martinek
mitsubishi 2201fwd
mt2201 with great bend hoe
   / ok lets see them pictures of your tractor! #2
I like the way your BH mounts high. Gives you clearance when using the loader. How deep does it dig? My guess would be 6.5'
ya 6.5 good little digger
and to the lbrown no i did not know of one i just signed up to this site
did you want me to delete this post?
   / ok lets see them pictures of your tractor! #6
Just got it yesterday.. Satoh Bull S630D
   / ok lets see them pictures of your tractor! #7
Here's a Beaver III I bought at the junk yard.
It looks really rough, didn't run and I paid more than I should've.
But I like it.
I found a few air leaks in the fuel system.
Put a used battery on it.
Replaced a freeze plug and a new radiator cap.
Three tubes, crossed my fingers and fired it up.
It runs good, the clutch is strong and it drives around in first. Only.
Once I get a look at the gear boxes I'll be consulting the Tractorbynet.com gurus as to what the loud grinding/rattling is in the back end.
The PTO works but the lift doesn't come up and the shifter won't put it into any other gears.
Here's a picture and a link to it running.
YouTube - ‪MrBubbasBulletman's Channel‬‏
   / ok lets see them pictures of your tractor! #9
I think this is just like the one I bought used. I need a hydraulic oil filter, any idea about where I can find one? I've been looking online without any success. If you can point me in the right direction, to a dealer or to a site, I'd appreciate it. I put a post in the hydraulics section of this site in hopes to reach out to someone who might know where I can get one. If you can help me out with the info, I'd appreciate if you could post it there. Thanks! H. Kuenzli
   / ok lets see them pictures of your tractor! #10
The filter on these is a fine mesh tube screen that you remove, clean and put it back in. It is located on the right side at the bottom of the rear case. I think it has two bolts holding it in. The only time you'd need a replacement is if the screen has a hole in it.
3 pallets of lockers (A53117)
3 pallets of...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A54814)
2021 International...
2016 FORD F-250 PICKUP TRUCK (A52576)
2016 FORD F-250...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54607)
2020 INTERNATIONAL...
11 SERVICE BODY BED (A53843)
11 SERVICE BODY...
2017 PETERBILT 579 DAYCAB (A53843)
2017 PETERBILT 579...
