OK to max out loader? (ie use it to its MAX capability)
   / OK to max out loader? (ie use it to its MAX capability) #1
beppington
Elite Member
of my
Here
What I mean is, if you need to lift something that your loader can barely lift, do you go ahead & do it? Or do you try to only lift things that don't seem to be excessively straining it? That seem well within its capabilities.
For that matter, same question for other uses. If you need to push a tree over, & your tractor can barely do it, maybe pushes & pushes but ends up spinning the tires, do you do that? Or, do you try to hold back some?
I had a large, dead curved oak trunk I wanted to move, & I could get my forks under it, but the loader could barely lift it. It did lift it, but I mean barely. I went ahead & moved it about 100' to where I wanted it. I could've put it back down, chained it & dragged it, but decided to carry it. Just wondered how hard that kind of thing is on the tractor.
   / OK to max out loader? (ie use it to its MAX capability) #2
Drive really slowly when carrying that much weight in the bucket. I worry most about the front axle when doing stuff like that.
When pushing a tree over, put it in low gear and let the tractor do what it can. Avoid dumping the cluch, ramming and jerking. A little wheel spin will only hurt your ground...the tractor will be fine.
   / OK to max out loader? (ie use it to its MAX capability) #3
Tractors, loaders, backhoes, etc... are all designed to perform much stronger than they do because they need to last. That's the reason for the pressure relief valves in the hydraulics. Your loader could lift more with a different relief setting but how long will the pistons hold up or the hydraulic pump, is there enough ballast, etc...
They turn down the power on these tractors enough to make them last a long time, your not harming a thing working it until it stops. It was designed to stop before it breaks.
   / OK to max out loader? (ie use it to its MAX capability) #4
If you have enough ballast aft of the rear axle (on your TPH) then you don't have to worry about it and you can load the FEL right up to bypass without worry. Just keep it near the ground and your hand on the control lever when you're moving and go slow. Loading up the TPH with ballast unloads the front axle.
I stopped pushing trees with the tractor. Almost had a top land in my lap. Tree looked sound, too. Some kind of critter had a home in a cavity about halfway up that weakened the trunk. Couldn't see any hint of it from the ground, though.
   / OK to max out loader? (ie use it to its MAX capability) #5
Pretty much in agreement with Dmace. I use all my stuff to the max and have all my life, that's why I buy it. So far no problems.
We do have some welds on our MF 375 FEL from loaning it to a relative who used it to ram with.
   / OK to max out loader? (ie use it to its MAX capability) #6
I agree with the others and also use mine to the max with the factory pressure settings.
I made a set of HD pallet forks and have concrete ballast that approaches the lift capability of the 3ph secured to a pallet that I can pick up when needed for stability and traction when using the FEL.
The rear ballast takes a lot of strain off the front end and also reduces the need for 4wd.
One rule to avoid injury & breakage is to carry low, go slow & don't ram-it!
   / OK to max out loader? (ie use it to its MAX capability) #7
Me, too...!!! Made a one ton concrete ballast for the rear when using the 2700 pound capacity loader. If you don't weigh down the rear, as you pick something heavy up with the loader... you transfer the weight of the load AND the tractor to the front axle.
   / OK to max out loader? (ie use it to its MAX capability) #8
I ascribe to the 80/20 rule. If you use your loader to its full capability 80% of the time, then you probably need a bigger tractor/loader, I actually think pushing to and beyond limits about 20% of the time is acceptable. Those are just my preference numbers and I think reflect my total loader use.
With most of compacts, the hydraulic system pressure relief and the hydraulic pump is isolated from the dual-remote loader valve when the joystick is centered. There is no relief valve in the loader lines nor in the joystick valves. If you carry a load near to the maximum lift capabilties, you can put stress loads on the hydraulic lines, hoses, and cylinders far above normal operating pressures. I have always wanted to "T" in a pressure gage in the lift arm "lift" side hydraulic circuit and then drive over rough terrain with a load. I think that would be an eye-opener, but I'd probably better use a 5000+ psi gage. If it is a liquid damped gage, I might not see the full spike either.
I agree that the pressure relief valve should protect the hydraulics when actively lifting or curling a load, however repeated lifting and shock loads with the joystick out of center position can feedback to the hydraulic pump. Last year when moving some big rocks that I could not lift with my loader bucket, I blew a seal in my hydraulic pump while using my rock bucket to try and nudge some big rocks across the ground. The pump's shaft seals finally gave up and started dumping hydraulic oil into the engine's crankcase. My relief valve is set at exactly 2500 psi, but it did not sufficiently protect my KYB brand hydraulic pump.
So from my experience, I'd say not to worry about overloading the hydraulics, but if you push your luck too often, you have to accept that you may have an unlucky event like I did.:(
   / OK to max out loader? (ie use it to its MAX capability) #9
You wont hurt your loader by maxing it out. I didnt even know tractors came with overload protection. Ive picked 2500 lbs up with my loader and never hit a limit. And its fine the ram trees. You have to do it fast though otherwise the trunk can snap halfway up and come back on top of you. I usually push the trunk as high as I can, back up and take off in 3 high. Works every time.
   / OK to max out loader? (ie use it to its MAX capability) #10
One thing I don't do any more is push over trees with the fel.Used to do it all the time;tried to push an old elm down,the top broke(widow maker) fell on to the lift arms of the loader.I was very lucky could have injured or killed me just as easy.
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
2020 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2020 CATERPILLAR...
2019 CATERPILLAR D6N LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
Three Point Hitch Finish Mower (A48837)
Three Point Hitch...
