OLD PROBLEM
   / OLD PROBLEM #1
DOVER
Dover, Indiana
New Holland TC18
I have seen a number of posts in this forum concerning broken
bolts that attach the belly mower frame to the transmission housing
on a TC18. I have had this happen three times and I now have
only two good holes to attach the mower. My solution is to replace
the transmission housing. Before I do this I thought I might see
if any of you have tried this yourself. I am going to the dealer to price
the parts today. Looking at the job, it doesn't seem like anything I can't
handle, but your opinions won't hurt.
   / OLD PROBLEM #2
Before I replaced the housing, I think I would drill out the hole and put a helicoil in them. Is a simple fix and not that hard to do.
I had to do that to my dozer tranny and it has held together just fine.
   / OLD PROBLEM #3
I don't know what that housing costs, or how much work it will take to replace it, but I would seriously consider a local machine shop before I paid for a housing, if I wasn't comfortable at repairing the broken parts myself.
David from jax
   / OLD PROBLEM
Just found out housing is $808.00 Local welding shop quoted "about 200
bucks", and I don't have to take it apart. Not a difficult decision.
   / OLD PROBLEM #5
Yeah, I agree, helicoil. Unless you have used one, it sounds difficult, but they come as a kit, you slightly oversize the original hole by drilling it out, then tap the hole, and screw in a new set of threads that are stainless steel and very durable. The kit comes with everything you need, drill bit, tap, several sets of new threads. Last one I bought, the entire kit was around $60.
   / OLD PROBLEM #6
If the only problem is the bolts are broken off in the holes, you should be able to remove the broken bolts rather simply with bolt removal tools you can buy at your local auto parts store. If the hole threads are screwed up however, THEN you'll need to drill and tap and install bigger bolts or a helicoil that will allow you to install the same size bolt in the bigger drilled-out hole.
The Art of Extraction
Unfortunately, I've had to remove my share of broken bolts.
   / OLD PROBLEM #7
Hmmmm, maybe the welding shop is my guess?
David from jax
2017 PETERBILT 579 (A53843)
2017 PETERBILT 579...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
Cat TH407C Telehandler (A53472)
Cat TH407C...
2005 Greatdane Trailer (A52377)
2005 Greatdane...
JOHN DEERE 444-624 - 60" LOADER FORKS (A52705)
JOHN DEERE 444-624...
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
