Old tractors sitting.
   / Old tractors sitting. #1
collector121
I have a few old tractors that I got from my grandfather. One is a JD 110 that has been sitting for I know at least 15 years. What should I do to clean the gas tank, carb and fuel lines out. Also, I am worried about when I start cranking this thing that it will lock up. I have changed the oil and it spins freely. Any thoughts?? Thanks.
   / Old tractors sitting. #2
It wouldn't hurt clean fuel system as you said.
Also check for bad wires etc.
Could remove spark plug than short cranks.
   / Old tractors sitting. #3
I'd also squirt a bit of oil in each cylinder and turn it over with the plugs out to get some lub on the cylinder walls and the rings.
   / Old tractors sitting. #4
Toadhill is correct about the major worry. Sometimes the rings get seized in place and making sure they are free is something you want to do.
   / Old tractors sitting. #5
Shoot some tranny fluid into the spark plug holes.
Does it have old fuel in it? If so, you may be looking at a total re-build of the fuel system. You may get lucky and only need a little carb spray.
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2001 HAULMARK ELITE II 8' X 24' CARGO TRAILER (A51247)
2001 HAULMARK...
(APPROX 25) UNUSED LANDHONOR PINS (A54757)
(APPROX 25) UNUSED...
2019 Allmand Bros Maxi-Lite II 15kW Towable Light Tower (A52377)
2019 Allmand Bros...
5' S/A CART (A52706)
2013 John Deere 35D Mini Excavator (A52377)
2013 John Deere...
