older simplicity garden tractor problem
   / older simplicity garden tractor problem #1
automech
SE PA
bx1500
I am posting this question for someone that has been having a hot soak no start on an older simplicity 15 horse Briggs twin. I think the model was a 1548. He states that it runs perfectly but will not restart after a hot shutdown. He must let it cool, then it starts. He wonders if it has something to do with the ignition system because it doesn't seem to have a very hot spark. I have not seen the unit, so I can't add much. He said he replaced the coil assembly and it still didn't help. Any help would be appreciated, since he's been struggling with this problem for a while.
   / older simplicity garden tractor problem #2
That sounds so perfectly like the ignition condenser to me- just the problem it will give. On battery/coil ignition if the points are set right and the spark is yellow, its the condenser which often when bad will not give itself away until the engine is warm. Also check coil to plug wire and spark plug boot.
-Fordlords-
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
International Acid Tanker Truck (A52377)
International Acid...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A53473)
2016 RAM 5500...
2010 UTILITY TRAILER MFG. CO. 53 FOOT FLATBED (A53843)
2010 UTILITY...
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A54607)
2007 PETERBILT 379...
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
