Oliver 3 bottom rollover plow (Farmwithjunk, you still here?)
   / Oliver 3 bottom rollover plow (Farmwithjunk, you still here?) #1
allen in texas
Platinum Member
Levelland, TX
Kubota Grand L 5740, loaded R1's w/640 lbs cast weight, 854 loader
Been awhile since I've been here. but once again I am on the plow prowl. To bring everything back up to speed, a couple of years ago I bought and "restored" a Ford 102 series 2 bottom roll over plow. There's a picture of it in my posts on this site. I pulled it well with a 32 HP (25 pto) Kubota tractor. I have traded up on my tractor (exactly double the HP) and I want a three bottom plow. I think I should be able to pull one ok.
I found an Oliver that may fit the bill and I will try to post pics of it later but I want to see if I can get a good guessing game going as to what it is. You know model, year manufactured, all that sort of thing.
The plow is a cat II set up as an 18 inch plow but it has 16 inch shares and moldboards on it. the main body of the plow has holes to convert from an 18 inch plow to a 16 inch or a 14 inch plow. It is also convertible to a two bottom because the entire rear third of the plow can be unbolted right behind the second bottom. The plow is rolled by a cylinder mounted across the headstock and turns the plow by means of a chain. I think some of the international plows use a similar setup to turn. Anybody want to play?
I also wonder what the effect of having 16 inch moldboards set at 14 inches would have on the performance of the plow.
Well I found a link to an old auction that has 4 or 5 pictures. of course that is not my plow but it is a picture of an identical plow
http://www.liveauctioneers.com/item/5118249
surely I haven't stumped this crowd...
   / Oliver 3 bottom rollover plow (Farmwithjunk, you still here?) #3
I don't know of many people with experience with these type rollover plows. I think they are used more in Europe.
   / Oliver 3 bottom rollover plow (Farmwithjunk, you still here?) #4
I think the problem you might have with changing sizes is the frame. It should be set up for 18" centers between the bottoms. If you put smaller parts on it you would either have to narrow the frame accordingly or it would leave a space the was not covered between the bottoms.
Either way I don't think it's a big deal. The 14's and 16's were designed for older tractors with less drawbar pull. They work a bit more efficiently at shallow depths.
Mendonsy,
I "think" I have found out what plow I am looking at. It may be Oliver 6240 and yes, if you change the bottom parts you also move the entire bottom on the frame. It is adjustable that way like I said, holes already provided. When you move the bottoms to the narrower holes, it places them closer together. I was wondering how the plow would work set up with 14 inch spacings and running the 16 inch shares and moldboards. The shares can be cut if need be but reshaping (or resizing) the moldboards is a serious undertaking.
Some of the expensive European plows can adjust the width of cut on the fly, all the way from narrow cut of 12" up a wide cut of 20 inches. They don't change the bottom parts so I think it will be ok to use the 16 inch parts with the plow set up at 14".
BTW, the math says I can pull three 16's but I'm still gonna set it up as a 14 inch plow. That is of course if I can win the plow at the auction.
   / Oliver 3 bottom rollover plow (Farmwithjunk, you still here?) #6
It should work just fine set up that way. The weight of a rollover may be a bit of a problem for balance, but nothing that adding some weight to the front of the tractor won't cure.
   / Oliver 3 bottom rollover plow (Farmwithjunk, you still here?) #7
For those of us who have never plowed, will you explain how a rollover plow differs from others and its advantages and disadvantages?
Trying to learn something every day.
Thank you.
   / Oliver 3 bottom rollover plow (Farmwithjunk, you still here?) #8
When you finish plowing, the last row leaves a "dead furrow" that doesn't get filled in. For small areas like gardens the rollover allows you to eliminate one of those and still work in both directions. It's a minor advantage and saves some time.
The drawbacks are that it is a LOT heavier and is more expensive, almost double on both.
And they're fun!! That's why I always wanted one.
Jeff, look at you tube. Lot's of plowing videos there of rollover plows.
   / Oliver 3 bottom rollover plow (Farmwithjunk, you still here?) #10
W&A 3pt Ditcher (A47307)
W&A 3pt Ditcher...
3030 (A46502)
3030 (A46502)
New Wolverine Auger 12'' & 18'' Bits (A48289)
New Wolverine...
2016 Bobcat S570 (A48561)
2016 Bobcat S570...
Rears 500 Gal Orchard Sprayer (A47307)
Rears 500 Gal...
3089 (A46502)
3089 (A46502)
