Oliver 770 industrial tractor
   / Oliver 770 industrial tractor #2
Looks like you have your work cut out. If I recall the Oliver Industrial tractors were orange.
Thanks for the reply. It was running, but has now died, and I'm trying to figure it out. I wonder if the tractor was painted yellow by Ware corp, the makers of the backhoe.
Here is an update. I still do not have it started, but am makeing progress. First off, there is no mechanical lift pump on this tractor. It relies on gravity flow to feed the transfer pump in the injector pump assemblly. The manual primer is just there to remove air from the system after changeing the fuel filters, or running out of fuel. The inline aftermarket electric pump added on my tractor negates the need for the hand primer when bleeding the system, and probably aids fuel flow in the case of a worn/tired transfer pump.
Here are a few links to the latest videos:
Part 8:
Oliver 770 Industrial Tractor Project Part 8 - YouTube
Part 9:
Oliver 770 Industrial Tractor Project Part 9 - YouTube
Part 10:
Oliver 770 Industrial Tractor Project Part 10 - YouTube
Part 11:
Oliver 770 Industrial Tractor Project Part 11 - YouTube
   / Oliver 770 industrial tractor #9
Keep the videos comin.
2008 Toyota RAV4 AWD SUV (A50324)
2008 Toyota RAV4...
1999 Case 1150G Crawler Tractor Dozer (A50322)
1999 Case 1150G...
43014 (A51691)
43014 (A51691)
Toro Workman 175 Sprayer Cart (A50324)
Toro Workman 175...
(4) 3 PLUG VALVES (A52472)
(4) 3 PLUG VALVES...
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
