Open center 2040 hydraulic noise
   / Open center 2040 hydraulic noise #1
dntfxr
Platinum Member
north Louisiana
Ford, LS
When I first crank up my '76 2040 before it warms up, the hydraulics squeal when I lift the three point hitch. Once it warms up a bit the squeal goes away and the hitch is silent. I've already replaced the fluid and filters/screen, and it still does it. Is it anything to be concerned about or is it normal?
   / Open center 2040 hydraulic noise #2
I wouldn't worry about the noise. The hyd oil has probably leaked back to sump while not running and when the oil gets replenished and the noise you hear is a hyd valve closing.
Good deal, I'm just wanting to make sure everything is good to go with this tractor before I put a loader on it. Thanks for the help Tx Jim
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A53473)
LIKE NEW 2023...
1995 Mazak VTC-16B Vertical Traveling Column Machining Center (A51691)
1995 Mazak VTC-16B...
2015 Ford F-550 4x4 Wrecker Tow Truck (A51692)
2015 Ford F-550...
2008 24ft. Haulmark Edge T/A Enclosed Trailer (A52377)
2008 24ft...
1996 Trailmobile 53 ft. Dry Van Trailer (A53117)
1996 Trailmobile...
