Open Center VS Closed Center
   / Open Center VS Closed Center #1
RottenGround
Bronze Member
Ozark, Arkansas
1974 JD 830, 1946 JD Model A
What is the difference in Open center VS closed Center Hydraulics please Explain
   / Open Center VS Closed Center #2
Excerpts
Open center circuits use pumps which supply a continuous flow. The flow is returned to tank through the control valve's open center; that is, when the control valve is centered, it provides an open return path to tank and the fluid is not pumped to a high pressure. Otherwise, if the control valve is actuated it routes fluid to and from an actuator and tank. The fluid's pressure will rise to meet any resistance, since the pump has a constant output. If the pressure rises too high, fluid returns to tank through a pressure relief valve. Multiple control valves may be stacked in series [1]. This type of circuit can use inexpensive, constant displacement pumps.
Closed center circuits supply full pressure to the control valves, whether any valves are actuated or not. The pumps vary their flow rate, pumping very little hydraulic fluid until the operator actuates a valve. The valve's spool therefore doesn't need an open center return path to tank. Multiple valves can be connected in a parallel arrangement and system pressure is equal for all valves.
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
2011 INTERNATIONAL DURASTAR 4300 M7 BUCKET TRUCK (A51406)
2011 INTERNATIONAL...
2016 Toyota Prius Hatchback (A53424)
2016 Toyota Prius...
Case 950 8 Row Air Planter (A55301)
Case 950 8 Row Air...
2014 Top Hat Industries 18FT T/A Utility Trailer (A52377)
2014 Top Hat...
