Operator was an idiot, bent bucket
   / Operator was an idiot, bent bucket #1
Wooddust
Western Missouri
JD3720
I got all carried away and managed to bend the cutting edge on my FEL bucket. Its not like horrible but it is far from straight. Im sure others have seen it happen. Suggestions on how to return it to a straight bucket?
   / Operator was an idiot, bent bucket #2
Probably have to post a pic to see how it's bent. If it's bent in the middle toward the top of the bucket you could use a 4x4 block of wood against the top of the bucket and a jack to bend it back. If bent the other way you'd have to brace up the middle and pull down the outer edges.
2018 Mitsubishi Eclipse Cross SUV (A53117)
2018 Mitsubishi...
UNUSED FUTURE FT-BC63 63" HYD BRUSH CUTTER (A51248)
UNUSED FUTURE...
2003 Ford E-350 Cargo Van (A51692)
2003 Ford E-350...
Hydraulic 50 mm pin thumb (A52384)
Hydraulic 50 mm...
2016 Crane Carrier Co. Low Entry New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
2016 Crane Carrier...
PAIR OF SOLIDEAL 15" RUBBER TRACKS (A51248)
PAIR OF SOLIDEAL...
