opinion on a 1215 cub
   / opinion on a 1215 cub #1
schalfback
Does any one have a opinion on the 1215? If so, is it a good model and what are its weak points. Are parts a problem?
Any input would be appreciated
   / opinion on a 1215 cub #2
I can't answer any of your questions.I did google 1215 it said it's a lale 80's model (88.89)I would have guessed early 90's.I am thinking its a lawn tractor and is a belt drive?If the image i got was correct,i do see these around from time to time or at least the same style maybe not model?So i am thinking it most have lasted or at least the ones taken care off?By the image i looked at it looks like the same tractor the guy down the road has but his is a 13?? something he has had it a long time but that is about all i can tell you.Hope someone comes along and answers you.
CC3235
CC1872
CC782
   / opinion on a 1215 cub #3
Indeed the 1215 is 87-88 vintage, 12HP Briggs engine, and belt drive. This is a "lawn tractor" not the GT variety so is lighter duty.
The better units are the 1200 and 1250, 1282 or 682-782 that are the garden tractor version with shaft drive, sundstrand hydro, and single or dual cylinder Kohler engines. They are built heavier and can be found in the $5-800 range.
I would probably avoid the 1215 unless just need a light duty lawn mower. The issue would be parts for either model will be a similar cost so you might as well have a GT.
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2001 Chevrolet Tahoe SUV (A50324)
2001 Chevrolet...
2007 INTERNATIONAL 4200 SBA 4X2 DUMP TRUCK (A50459)
2007 INTERNATIONAL...
2014 Chevrolet Tahoe (A50324)
2014 Chevrolet...
2012 Volkswagen Jetta Sedan (A50324)
2012 Volkswagen...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
