Opinions needed about water storage & Diesel Fuel storage
   / Opinions needed about water storage & Diesel Fuel storage #1
brin
Super Member
Georgia - Mt. Vernon by The Store just 5 miles eas
I would like to have a large tank like this , 250 gallon tank, to store drinking water in the event of a prolonged power failure or who knows what else...We have a drilled well and I have a PTO generator but if it was a real calamity I would eventually run out of diesel fuel....so I was thinking it would be nice to have this tank for extra water storage...I have posted the craigs list ad below...Question is ...what if poison or weed killers or some other noxious chemical was once stored in the tank...? Would bleach be enough to clean out any remaining toxins ?
Second question....I have a 55 gallon plastic barrel I currently use to store my diesel fuel...does this look like it would be alright to use as diesel storage as well....? These type tanks are new to me...anyone have any knowledge of them...?
MUST GO!***250 Gallon Water Tank in Metal Cage***
   / Opinions needed about water storage & Diesel Fuel storage #2
You should be able to find a food-grade one. I posted a wanted ad for a food-grade one and got a response in a few hours. It has glucose in it. Some bleach and water will take any smells out of it.
As for storing diesel in one as long as it is clean and the previous stuff in it won't react with the fuel it should be good.
They seem to be very robust. I can stand on top of just the plastic on my tank and it doesn't even bend.
   / Opinions needed about water storage & Diesel Fuel storage #3
"Food Grade" per: Mike R - is the way to go. I see them often on Craigs List. Question - Do you plan to fill only in times of emergency or keep it full continuously? I ask because you describe it as a source of "drinking water" and water stored as a static reserve will eventually be unsafe for consumption unless treated.:2cents:
   / Opinions needed about water storage & Diesel Fuel storage #4
Diesel will store for a long time. Biggest factor is moisture, which can lead to fungal growth. Minimize openings and use an additive to inhibit any organic growth in the fuel. You still need to have a "breather" for thermal expansion/contraction. If you spend some money you can get a desiccant breather. This has a desiccant to absorb moisture in the air that flows into the tank.
paul
   / Opinions needed about water storage & Diesel Fuel storage #5
There is a chemical plant in Arkadelphia that you can get those for free. They are washed clean with no smells evident. I got one that I was going to use to water my trees but ended up giving it to my garbage collector. They would make excellent diesel storage tanks. They have a shut off valve on them already. Just elevate it and build a platform for the fuel delivery guy to step up on and you would be almost in business, Just need to by hoses to fit with a fuel nozzle. Check some of the plants around you. The one I got mine from gave me the MSDS sheet also for what came in it.
As stated, water would grow bacteria in it if stored over a very short period of time if not highly chlorinated. You could treat it yourself with common bleach. Google it for proper ratio in PPM for effective treatment and still be safe to drink. It might work for Hurricane preparedness. JUST fill it just before the hurricane hits and it would keep for a few days without treatment as long as it was dry and clean before hand. Even bottled water if it is not carbonated has a "use before" date on it that most folks don't notice.
One thing about carbonated drinks and long term storage that folks don't know about. The cans will eventually start leaking from carbonic acid in the drinks if stored in outside unregulated temps. On a project we had once the Proj. Mgr. was providing the workers with sodas in the mid- morning and mid-afternoon during the hot summer days and had stocked up several dozen pallets of them (several hundred cases). After a few months, they started to leak with little pin holes in them. At first we though someone was sticking holes in them with a needle or push pin but they continued to develop inside the wrapped pallets where not one could reach them. It was then that we found out that they have to be used quickly or the acid eats thru the aluminum cans. I think this is why stores sometimes put them on super sales to clear their old inventory. We had to start rotating the stock to get rid of the older stuff and not order so many at a time. We had over a thousand workers so it didn't take long to go thru them@ 2000 per day
   / Opinions needed about water storage & Diesel Fuel storage #6
The water may not be drinkable after long-term storage but it works great for flushing the toilets :)
Also, could just boil it to drink it right :)
   / Opinions needed about water storage & Diesel Fuel storage #7
If you have a gen set, I don't see the need to store water, just pump it out of your well. A lot of people around here are converting from oil to small heat pumps, and If you go to your local freecycle.com site you might be able to get a 275 gallon diesel tank with diesel for free. I got one of the tanks with 125 diesel for free.
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
2001 JOHN DEERE 310G BACKHOE (A52705)
2001 JOHN DEERE...
Echo Weedeater, Stihl Pole Saw & Predator Gas Auger (A50123)
Echo Weedeater...
2023 Vivid EV Electric Cart (A51694)
2023 Vivid EV...
