Buying Advice Opportunity or pass on this deal for John deere 2130?
   / Opportunity or pass on this deal for John deere 2130? #11
That is an elglish or german row crop tractor made before the modernization, most had headlights on the front. So the transmission is always weak and clumsy. It probably has a row crop rear tire like a 13.6 when a 16 or 18 wide is better for loader work. some of them didnt have live pto depending on how it was ordered. The hyrdaulic pump might be a tad slow.
On the plus side
its a deere find a hood and decals for a 2030 and swap most would never know the difference and it is night and day.
Sell it and buy something more suitable
Transmission is std, collar shift. 8 forward, 4 reverse, 16 and 8 if you count the hi/low. It has 15.5-38 rear tires. I am going to get it, fix it, and use it for a while. If it isn't suitable, will sell it and get my money back out of it. No harm, no foul. 75hp tractor for 2000 in repairs is a bargain, really. Will easily do my food plots, roads with boxblade and bush hog. By the way, it comes with a working bush hog with slip clutch, which is a bonus.
   / Opportunity or pass on this deal for John deere 2130? #13
Do you know the hours? Is the engine in good condition? If you'll have to split the tractor to fix the tranny, it would make sense to do a new clutch for it at the same time. If it's otherwise a healthy machine, you'll have a good old workhorse that should last as long as you need it. It makes sense for many people to have two tractors: an older one like you've found and a smaller compact with all the modern conveniences. You've maybe changed it around a bit by getting the old workhorse first, but it sounds like a great find. Share some pictures as you get it back to good health, if you can.
   / Opportunity or pass on this deal for John deere 2130? #14
According to Tractor house*com it appears to be about an average of $7000. I would consider fixing it and trading it on a tractor loader combo.....
Good luck....
   / Opportunity or pass on this deal for John deere 2130? #15
Al,
That is a good find if you can fix it up as some have suggested. If it can be fixed up for a reasonable amount you can do alot more semi field work with it than the smaller tractors. With 100+ acres I think I would keep it to handle the larger jobs rather than trading as many have suggested. If you can fix it up and have a good working tractor for $5000 approximately that would be a great deal for you.
While you may still want to get a smaller tractor with fel for close work the little you would have invested in the larger tractor would save alot of strain on the newer and smaller tractor.
   / Opportunity or pass on this deal for John deere 2130? #16
HI-LO does not give you 16 forward & 8 reverse speeds. HI is basicly the gear you are in, LO is very close to dropping down one gear. So if you are in 4th gear and HI-LO is in HI, that is 4th gear. Shift to LO and it it's almost the same as dropping to 3rd, shift back to HI and you are in 4th again.
There is a hydraulic clutch pack in the HI-LO unit in addition to the main dry clutch. Repair requires splitting the tractor. If the HI-LO is bad, I estimate $4000 to repair (by dealer)
Thanks so much for the information. Tractor has about 2200 hours on it. Engine in good condition. It was running fine last year until transmission starting causing problems. I am not going through the dealer, just local mechanic who I know does a good job. He will have it on Monday and give me the diagnosis and estimated cost. Will update you then.
2017 John Deere 9620R Scraper Special Tractor (A53342)
2017 John Deere...
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
2018 Komatsu WA380-8 Articulated Wheel Loader (A51691)
2018 Komatsu...
2011 KOMATSU PC56-7 EXCAVATOR (A51246)
2011 KOMATSU...
Kubota Salt-Spreader (A52384)
Kubota...
