Richard
Elite Member
- Joined
- Apr 6, 2000
- Messages
- 4,999
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
You are driving your car and you realize that (even after a 4-wheel brake job) there is some shimmy in the steering wheel when you apply brakes. You can also sense a speed dependent but background "whoh whoh whoh" (like that sound?) as the wheel turns. Faster speed means faster 'whoh woho whoh' and slower means slower. It is clearly a speed dependent sound. The shimmy in the steering wheel is also speed dependent. Going 60 mph and start to slow down you can feel the whole front end shudder.... lay off the brake a bit....reapply them and though the shudder is still (clearly) there, its magnitude seems to be greatly reduced. Almost like some slack has been taken up.
You feel as though the sound is coming from the rear wheel bearing so you raise the back end and spin the wheels. You have to do them both because the first wheel was essentially dead silent. There is a faint rub as it hits a certain spot but they both seem to do that and it doesn't strike you as a significant sound so your gut instinct tells you it's not the rear wheels.
This is further supported by the shimmy that you get in the steering wheel. (that it's the front wheels and not the rear)
You have not yet raised any of the front wheels to take a listen to them while you rotate them freehand so you don't know if they are going to be silent or sound like grinding metal (doubtful since it's likely on the earlier stage)
Would your opinion so far that it would be the front wheel(s) making the shimmy & vibration problem?
If so, I'm mechanically inclined but never done a wheel bearing assembly on a front wheel drive car. Any special tools needed?
I've got the wrenches, impact tools, I forget what it's called... a 'fork' like tool that is used to wedge into ball joints (if I recall) and of course I have a big mean hammer to hit something when I get upset.
Any issue on tools? If I swap it out, does this require a front end alignment afterwards?
Should I get the rotors turned while doing this since I'll have it apart anyway and put new brakes on the front? Kind of a free brake job for myself.
What say you?
What say you?
