OTA TV signal fades 50 min into program
   / OTA TV signal fades 50 min into program #1
RedDirt
Northern Idaho
Kubota BX23, Wards 16HP HST Garden Tractor, (previous) D2 Logging Cat
This is a question for those getting the new digital TV signal over the air via an antenna and specifically addressed to those in deep fringe areas.
Many, many times we get decent signal and viewable reception for the first 3/4 of a 1 hr show and then the signal fades in the last 10-15 minutes into the program...blue screen. At the top of the hour the signal strength goes back up to viewable. This is VERY annoying.
Does anyone else experience this phenomena or is it just us?
FYI-We are in Northern California pulling signals from Sacramento from what is considered a "deepest fringe" location. Antenna farm is 78 miles away through a forest of trees and two mountain tops. We've upgraded our antenna to high gain UHF only w/high gain/low noise pre-amp and new coax. I researched a lot and got the best equipment I could find for our location. Signal often fluctuates widely from good to bad (aggravating but understandable) but it is extremely odd to regularly loose an excellent signal 50 minutes into a 1 hr program.
I was perfectly satisfied with analog TV, snow and all. This digital dung is for the birds! I personally think the digital change, despite some valid and worthwhile reasons, was overall a ploy to switch us all over to cable and satellite. I now wonder if the signal reduction just before a show ends is an extension of this evil game. Please tell me you too are in a deep fringe OTA location but are not having the same signal loss just before a program ends.
   / OTA TV signal fades 50 min into program #2
I am in the same boat at my cabin 70-80 miles from the stations and I wonder what antenna you picked.
I was happy with analog and don't spend enough time for dish and no cable or power available.
From what I'v been reading some of them are really directional.
If you have a rotor maybe tweak it a point or 2 in each direction to see if it gets better?
It almost sounds like a heat issue,
Borrow a converter box plug it in to the game ports and eliminate the tv's tuner as the problem.
Do any other tv's on the system have the same problem?
tom
   / OTA TV signal fades 50 min into program #3
Thats a strange one. So you do nothing to correct the problem it just starts working again at the one hour mark? No power cycle, no switching channels etc?
It does this on more than one station? If so it has to be your equipment.
No idea what it could be though......can't wait to hear what it is if you ever resolve it!
   / OTA TV signal fades 50 min into program #5
Actually it is a plot to move 'over the air' TV into a very small section of spectrum so the government can auction off the relatively large section of spectrum used by analog TV. They made billions auctioning off spectrum to cell phone companies and they are looking for a repeat.
Yep, I do nothing to correct the lost signal and ten minutes later, usually at the top of the hour, the signal returns. This happens on many channels but I have not tried to single out specific channels except I know it occurs often. Often meaning about 30% of the time when watching first run popular shows. It rarely happens when viewing garbage "fill-in" reruns though I can't say for sure since I rarely watch them except occasionally while channel surfing waiting to regain signal.
My solution may be to succumb, kicking and screaming, to satellite. The only good news is that DigitalPath internet (wireless) is now in the neighborhood so I may be able to switch my very expensive satellite internet (WildBlue-$80/mo) and get twice the speed at half the price and with that savings pay for the satellite TV.
Before satellite I may try one more thing and build a super antenna. Here's a link:
Design of The Gray-Hoverman Antenna - Digital Home Canada
Tommu,
Only have one TV. It's analog and I'm getting digital through a DitalStream converter box.
Antenna is Terrestrial Digital XG91 which was rated higher than the best ChannelMaster or Winegard. Pre-Amp is Winegard Chromstar 2000. Pre-amp is mounted on antenna mast just below antenna with new short length of coax and new coax run directly to converter box, eg no splitters, etc. Total run of coax is 40ft-50ft.
I have a rotor but rotating does not improve reception when signal is "down".
GT2 - Thanks for the link. I'll check them out.
Charlz,
Yes I am aware of the govt sale of the analog bandwidth. I imagine a lobby campaign to rival the pharmaceuticals and much graft was in play.
   / OTA TV signal fades 50 min into program #7
Red thanks for the info.
I have the same digital stream converter and a cheap old RS antenna.
I guess I will have to invest in a rotor and new antenna
tom
   / OTA TV signal fades 50 min into program #8
Where are you? Here in Shingle Springs, we gained a bunch of channels in the switch to digital. We are not too far out of Sac though.
We put a TV in the 5th wheel. With the trailer plugged in to power, I get a ton of channels with the RV antennae, although I do turn on the amplifier.
It would be hard to say what the issue is. It happens on the hour, so that would rule out atmospheric issues. My first thought would be heat in the converter box, but that would just continue to get worse.
Have you recently did a "search" for channels to get any updates?
It would be worth it to try another converter.
If you are near me, I can bring the digital tv from the 5th wheel by and see if it is any different.
RobertN,
We are north of Grass Valley, east of Oroville.
We gained a bunch of stations too with digital. The price has been any semblance of reliability. Reception is touch and go most of the time; some days fairly decent and reliable but other days hardly usable. Sometimes all signals fade away and other times just some of the channels go. Mostly it seems signal strength is normally better in daylight hours, often fades or diminishes at dusk and then rather spotty in the evenings. Maybe it is atmospheric but I have not been able to come up with any specific correlation night/day, summer/winter/ hot/cold, clear or stormy.
At least there has not been a flood of replies "Yeah I loose the signal too just at the end of a program". So maybe it's just a coincidence I loose signal then, or I notice the loss of signal more because it is at the end of the program. You do have to admit that it is odd, especially when we normally regain signal just after the program has ended.
I have not done a search in quite a while; I'll try that. Thanks.
Tommu,
Upgrading to a good antenna and pre-amp is not very expensive (especially compared to endless monthly satellite bills!). I got my equipment from solidsignal.com, a good company with good equipment selection and good tech info and very competitive pricing. My new pre-amp lasted only one day and they sent a new one immediately, no questions, no cost. You also need relatively good/new coax and good connections to get the best signal and no splitters between pre-amp and converter. I think replacing my antenna, preamp and some older cables cost about $120 -$140.
FYI - A pre-amp is placed as close as possible to the antenna and gets the signal down to the converter without further losses which normally accumulate with length of cable run and each connector. An amplifier is used when you want to split the signal and send it to several locations. It is the pre-amp that you need to get the best strength to the converter box.
   / OTA TV signal fades 50 min into program #10
You know, just for grins and giggles, I would bounce a message off KOVR and KCRA. Maybe send it to thier "Call 3 for action" or "Ask Kurtis".
There are some Techie guys over at KVMR.org in Grass Valley. They may have some idea's.
2022 CATERPILLAR 980 WHEEL LOADER (A51246)
2022 CATERPILLAR...
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
New/Unused 13ft x 20ft Single Garage Metal Shed (A51573)
New/Unused 13ft x...
New/Unused 72in Quick Attach Mower King Hydraulic Brush Cutter (A51573)
New/Unused 72in...
2025 New/Unused Wolverine Hydraulic Skid Steer Pallet Forks (A51573)
2025 New/Unused...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
