Outside width of XR4046HC?
   / Outside width of XR4046HC? #1
AaronS
Platinum Member
Santa Claus, Indiana
LS XR4046HC, New Holland Boomer 1020
Can any of you 4046 owners tell me the exact outside width of the machine? I want to make sure I get a mower that covers the tire tracks. Thanks!
   / Outside width of XR4046HC? #2
What type of tires? 72 inches will cover my xr4046c with R-4 tires.
I plan to go with ag tires - R1.
   / Outside width of XR4046HC? #4
With R-4 tires the tractor is 69 inches wide . With the R-1 tires you should be about 61 inches wide. The R-1 rear tire size is13.6-24.
Thank you snowbelt.
Ok new question, can you adjust the width of the rear wheels on the 4046? The LS website says the "minimum" width with ag tires is 62.4, so that has me wondering if it can be adjusted.
   / Outside width of XR4046HC? #7
I was told by my dealer yes by flipping the tire over. Putting the rim inside out.
Thanks again!
Dealer just told me that they can set the rears to widest width and they'll still be under 72", so a 6 ft mower will cover and I'll maintain stability. Looks like I'll stick with the R1s.
2018 Ford F150 4x4 Pickup Truck (A51692)
2018 Ford F150 4x4...
Manac Walking Floor Trailer (A50322)
Manac Walking...
WESSEX CHT-100R-E LOT IDENTIFIER 46 (A53084)
WESSEX CHT-100R-E...
4' DRAWBAR SCRAPE BLADE (A51248)
4' DRAWBAR SCRAPE...
UNUSED JCT HYD HD BACKHOE ARM (A51248)
UNUSED JCT HYD HD...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A53426)
PEMBERTON...
