Over Seed Sandy pasture or till and seed?
   / Over Seed Sandy pasture or till and seed? #1
MNBobcat
Platinum Member
Hi Guys,
I have a 15 acre field that I'll be flying an ultralight off of. Its currently grass and a lot of different kinds of weeds. The grass isn't thick and there are a lot of small patches of dirt. I would like to get some thicker grass growing. I've been dragging the field to level it and that has brought up a lot of sand. I'm trying to decide between hiring someone with a no till drill to seed it for me or tilling it all up and then seeding it. I'm concerned that if I till it all up I'll have trouble getting the grass to grow in the sand.
Would you recommend I have someone overseed it for me or would you till it all up and start fresh?
   / Over Seed Sandy pasture or till and seed? #2
Hi Guys,
You could check into hydro-seeding as a third option.
Dave.
   / Over Seed Sandy pasture or till and seed? #3
Well it all depends on how smooth your ground is to start with. and it all depends on where you are located to what kind of grass will grow the best with the least disease pressure, drought tolerance and wear capability etc.
Till I find out exactly where you live a would just say over seed with an aggressive grass for your area, topdress with sand ( for drainage and firm surface) roll with a roller to smooth and add nitrogen in the spring to encourage good growth.
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
2017 PETERBILT 579 DAYCAB (A53843)
2017 PETERBILT 579...
UNUSED LANDHONOR TP2-13-08D HYD TREE PULLER (A54757)
UNUSED LANDHONOR...
2019 Allmand Bros Maxi-Lite II 15kW Towable Light Tower (A52377)
2019 Allmand Bros...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
