sycamore
- Joined
- Aug 17, 2006
- Messages
- 24
- Location
- Bismarck, ND
- Tractor
- Kioti NX6010; Kubota B3200; Ford 9N; John Deere X360
Hi - Could use some more help. I have a set of Everything Attachment 42" pallet forks on my Kubota B3200 using the Kubota quick hitch system. BTW, the forks are EXCELLENT and I want to thank Ted and his gang for their good work. Also have a set of Ted's larger 48" forks for my Kioti NX6010 using SSQA; also EXCELLENT. I always power wash my rotary and finish mowers in fall or spring at the same time I sharpen blades, check things over, etc. I have a Farm King 72" finish mower for the Kubota B3200, and I like to lift it to the vertical position at the very end of the forks to do this work. As you might guess, I could use just a little more height and would like to move the mower just a little further away from the tractor. Will need some counterbalance on the 3 pt. to make this work safely but have that part well in hand.
So here is my challenge. I see many, many pallet fork extensions for sale, but what I am looking for is something that would be maybe 12" - 18" long (just the extra length I need to get further away from the front of the tractor) and maybe go up at a 20 degree angle or so (to give me the extra lift to get the mower a little higher off the ground) and at the end have cradles or maybe even better full enclosed loops that I could use to run a chain or strap through that I would attach to the mower. Hope that paints a clear enough picture of what I have in mind.
Maybe I don't know what to call that kind of device if it exists; when I type things in to search engines I never find anything like that. Anyone got any suggestions about where to look or I guess maybe if you've ever heard of or seen anything like that? I have a pretty good repair shop that could probably make me whatever I'd need but with all the good, innovative folks on here I thought maybe someone had already filled the need. Let me know about any ideas you have.
Thanks.
keith
Thanks.
keith
