parts availability
   / parts availability #1
dbltrbl
mitsubishi satoh s470
Hi fellas. New member here. I have a Mitsubishi Satoh S470. What is a good source for common parts sucha s filters etc.?
   / parts availability #2
NAPA air filter # is 6270. Fuel is 3264.
Thanks for the info guys.
   / parts availability #6
I forgot to tell you the oil filter # is 1334 at NAPA
I was able to get all the filters I needed. The only part I need now is a tach cable. Also, has anyone found matching paint colors?
   / parts availability #8
There's a Ford engine enamel in a spray can that is a dead ringer for the Satoh blue. I've used it, and you can't tell the difference in color. Plus, it's good paint, high temp and everything. I still have the can if you need the #. I think I got it at Tractor Supply.
   / parts availability #9
For the off white paint I use the white paint for International Harvester. This is also available at Tractor Supply.
Thanks. I'll pick some up.
2003 Walk-Behind Automatic Seed Spreader (A54811)
2003 Walk-Behind...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
2020 KUBOTA SVL95-2S SKID STEER (A52706)
2020 KUBOTA...
PENDING SELLER CONFIRMATIONS (A54607)
PENDING SELLER...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
