Pasture Dream Clipper Brush Hog -Remove Blades
   / Pasture Dream Clipper Brush Hog -Remove Blades #1
jay emmo
I'm having trouble removing the blade on an old brush hog. The mower is a 5 ft Pasture Dream Clipper made by Taylor Machine Works. I'd be afraid to guess how old it is, I bought it used 20 years ago and it looked very old then. The blade bar has a sleeve on top that fits on the shaft that comes out of the gear box. A heavy bolt goes up through the bottom of the blade bar into the shaft. I've never had the blade bar off but I assume there is either a key way or splines to keep the sleeve/blade bar from turning on the drive shaft. While under the deck to sharpen the blades I noticed a crack in the sleeve which I'm hoping can be repaired by welding. I can get a socket on the bolt that goes up through the bade bar, but it will not budge, even when using a cheater bar. I'm assuming the bolt is right hand threads, but maybe they are left handed. Anyone have any suggestions?
   / Pasture Dream Clipper Brush Hog -Remove Blades #2
You might have to heat it but don't do this unless you plan on replacing the seal.
I'd first get a 3/4" drive breakover bar and a put a 3-4 foot cheater on that.
   / Pasture Dream Clipper Brush Hog -Remove Blades #3
Assuming you can't get an impact wrench to it, have you tried "tapping" your breaker bar; sometimes I can break something loose I can't get with constant pressure. If you do, use an impact socket.
And agree, longer cheater bar often will do the trick; won't mention the other methods I've used.
   / Pasture Dream Clipper Brush Hog -Remove Blades #4
I suggest a set of torches and plenty of heat. I'm afraid the bolt would break without heat.
   / Pasture Dream Clipper Brush Hog -Remove Blades #5
I also would try heat and if the seal leaks, it should be easy to replace. Ken Sweet
   / Pasture Dream Clipper Brush Hog -Remove Blades #6
My vote is for lots of PB Blaster or Kroil and impact wrench.
Thanks for all the suggestions, I'll try again this weekend.
   / Pasture Dream Clipper Brush Hog -Remove Blades #8
Did youever get this fixed? I have a Clipper 5" mower - it is a 3/4 fine thread left hand bolt - if you break it, you probably will not be able to find it anywhere. It is an old Warner grarbox and parts are not available.
   / Pasture Dream Clipper Brush Hog -Remove Blades #9
FWIW, I have had good luck finding left hand threaded nuts and bolts on Ebay. Just bought a 5/8" fine thread hex nut for $2.22 delivered. Ken Sweet
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A59575)
2018 FREIGHTLINER...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56438)
Kuhns AE10 Small...
Hyster H155 XL Forklift (A59213)
Hyster H155 XL...
17501-FL (A56857)
17501-FL (A56857)
PowerBoss Admiral Plus 38C Ride-On Floor Scrubber/Sweeper (A59228)
PowerBoss Admiral...
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
