Pathetic Tire Shops these days
   / Pathetic Tire Shops these days #1
MNBobcat
Platinum Member
When I was 17 I used to work in a tire shop. I used to work on tractor tires (some taller than me. Some filled with fluid), Semi Truck tires, car tires, you name it. I used to work on the split rims that you had to know what you were doing or they could kill you. We didn't have no OSHA cages for split rims. While airing up a split rim we continually pounded the split rim ring, all around, with a hammer to keep it in place and not have it blow your head off while airing it up!
Never worked on a big earth mover tire but other than that in a tire shop back in the day (1979) you pretty much saw it all.
I even ran a hydraulic crusher that would crush the tires/rims so you could separate them and sell the rim for steel value.
Fast forward to now.... I got the skid steer stuck in the mud yesterday and I popped a bead and filled the tire with mud. That means the tire has to come off the rim and get cleaned and then put back on the rim again. I could easily do it myself in about a half hour if I had the 3 foot long tire irons that I needed but unfortunately I didn't have the right tools.
Called at least 15 tire shops and none of them would do a skid steer tire. Are you kidding me? You are not a real tire shop if all you can do is a car tire using the brainless tire machines to do all the work. Heck....we used log splitting wedges and a sledge hammer to break a bead on a tractor tire.
Sheesh! Kids these days.
Anyway...finally found a John Deere dealer who was able to fix the tire today.
I ordered two 3-foot long tire irons from Northern Tool today. Next time something like this happens I am not going to be dependent on the pathetic excuse for a "tire shop" that seems to be prevalent now.
There may be a small handful of shops that will do a skid steer tire but that might be 5% of the shops today.
   / Pathetic Tire Shops these days #2
Unfortunate experience. No idea where you are but in the PNW its Les Schwab to get any tire fixed.
   / Pathetic Tire Shops these days #3
Understand there are different kinks of tire shops. Automotive (cars and light trucks), industrial tire shops, and still other shops that will handled them all like oosik pointed out.
It has nothing to do with "kids these days". Equipment, training and liability plays a big part. Times have changed since we were all kids. Safety and ambulance chasing lawyers have had a lot to do with it.
   / Pathetic Tire Shops these days #4
[QUOTEWhen I was 17 I used to work in a tire shop. I used to work on tractor tires (some taller than me. Some filled with fluid), Semi Truck tires, car tires, you name it. I used to work on the split rims that you had to know what you were doing or they could kill you. We didn't have no OSHA cages for split rims. While airing up a split rim we continually pounded the split rim ring, all around, with a hammer to keep it in place and not have it blow your head off while airing it up!][/QUOTE]
Tire shop??? I worked on ALL of those tires in my Dad's Mobil service station in Texas when I was 17. But then when I was in my early 50s, I worked in my brother's tire dealership in Anchorage, and as you said (and Oldoak explained), we only worked with car and light truck tires. Incidentally, there's a difference between the "split rim" and "split ring" truck tires. I got more experience with both than I wanted.:laughing:
   / Pathetic Tire Shops these days #5
Yeah in the "good old days" (1980s and before) the fatal injury rate was 10 deaths for every 100,000 workers....it now hovers around 5.
   / Pathetic Tire Shops these days #6
"I ordered two 3-foot long tire irons from Northern Tool today."
....and you can bet those tire irons are not made as good as the ones from the 70's either.
   / Pathetic Tire Shops these days #7
Tire shops here are very picky...
I wanted to buy tubes that they had in stock and refuse to sell them to me without seeing the wheel first.
Needed to have a tire moved from my spare from one trailer to the rim for another... said the tire is 5 years old and they would not be able to re-mount it.
For as "Careful" and concerned with liability these days too many rims and lug studs are still getting over torqued or cross threaded... with no mind.
I always do my own work but hit shrapnel on the highway and bought a new Michelin Tire and mounting for the truck... I heard the guy say something but was in the customer area...
Drove the truck for a couple of thousand miles... my truck has wheel covers.
Go to check my brakes and one stud is missing... totally gone... try to loosen the nuts and can't... get the torque wrench and 275 lbs is a high as it goes and some were that tight...
Truck bought new and never had a impact wrench on it except when new...
The nuts washed out the rims and stretched the lugs and cross threaded one nut...
Contacted the company and was told it was over 30 days...
   / Pathetic Tire Shops these days #8
Your story brought back memories, around 1966 I turned 16 and wanted to work for real money not just for my dad. So he said I'll find you work. First year was the canning factory, man that was like dawn of the dead, steam whistle would blow and all the kids and women would come out and start walking to the canning factory, you worked until everything picked that day was canned, I also did clean up and regularly put in 11 hour days. Next summer I said how about better job Dad said sure, so 7:30 am I found myself at a truck stop, that did maintenance on KRAFT and Hammermill paper trucks. So I changed repaired split rims tires all day long, then got promoted to bearings and brakes, finally oil changing and grease jobs. Finally after years in college and I stopped coming home for the summer to work, found much better job on campus that Xmas my Dad said it is about time, wondered how long you were going to keep letting me get you the crappyist jobs I could find to make sure you went back to school in the fall. You know it worked
   / Pathetic Tire Shops these days #9
The local tire store will change everything even loader or skidder tires. And they’ll give you a ride back to work if you’re buying a set of tires or having major work done. I’ve pressure washed the bead out on broken beads filled with mud. It’s probably not an ideal solution but it beats spending 3 hours and probably $50 dealing with it.
   / Pathetic Tire Shops these days #10
Where "I" live, there would be NO problem at all, getting that tire fixed!
In fact, there several places around here, that will come right out to your place and fix a tire like that. All you have to have, is money!
SR
   / Pathetic Tire Shops these days #11
Time have change...quick sales long wait on recalls.
   / Pathetic Tire Shops these days #12
I’m not sure what that has to do with the problem in the first post. And there’s a lot more cars on the road then skid steers so it’s logical that more tire shops only work on car tires.
   / Pathetic Tire Shops these days #13
Our local stockfeed store does onsite tractor tyre repairs, and to boot he is a lot cheaper than the one who covered the area before and had the monopoly.
Word is out and what started as an experiment 2 years ago now employs three men for this work.
   / Pathetic Tire Shops these days #14
It's all about the OP's location and the clientele that tyre shop is, economically, going to receive. In other words, if it's urban/semi-rural then the tyre shop's bread-and-butter is the vehicles of that area.
My local tyre shop caters to RV/caravan tyres... lots more tourists are coming through all year round now. They do tractor tyres too, although I don't believe that they'll do on site service. Heck, they've even repaired/replaced the tyres/tubes on my 3-wheeled barrow.
   / Pathetic Tire Shops these days #15
MNBobcat - try Fleet Farm next time. They will do tractor tires, etc. otherwise, yeah it can be a challenge to find a shop to handle tractor and equipment tires.
   / Pathetic Tire Shops these days #17
Amen, they are well, known and thought of west of the Rockies. If they don't have it they will get it. They have a lock on the farmer market in the Willamette Valley in OR.
Ron
   / Pathetic Tire Shops these days #18
I've had it with Tires Are Us type shops. Had an 1986 Olds Delta with stock aluminum rims. I needed all new tires so I went to a TAU shop. During the next few months I found a couple nuts were loose and some were very tight. I had a flat tire and it seemed like the nut was welded on it was so tight, even though I am a big guy. I do understand re-torquing is necessary but hardly ever do it. I looked at the owners manual and said to torque to a specific number, so I did and all was good after that.
A couple years later I went to the same shop for more tires and I politely explained at the desk of my plight last time, and I want all nuts hand torqued. He seemed torqued.
I watched the mechanic install through the window and could see he did not do as I wanted. They pulled the car outside then I complained the lug nuts weren't torqued properly. Th manager almost blew a gasket on my. He explained that the "torque stick" on the gun was very accurate. He brought the mechanic outside with a "real" torque wrench and checked half a dozen lugs and the majority were okay and told me he wasn't going to check any more and stormed off.
I then grabbed my own torque wrench, not a high dollar one like theirs, but a Sears. I checked them on my own and of the 3 wheels they didn't check there were 3 nuts were quite loos and one nut I spun farther on by hand at least 2 full turns.
Would it pay to tell him that, **** no. I just never went back in the Tires Plus store. All it would have taken was one minute to check them manually to keep a happy customer hooked.
Great story! Smart dad!
   / Pathetic Tire Shops these days #20
We have local tire shops here that will change any tire you can get to them. We have chain mega tire stores that only handle car and trailer tires. We also have remote service tire companies and several locally owned remote tire folks. At my age those are the ones I use for the tractor.
2016 CATERPILLAR M322F MOBILE EXCAVATOR (A60429)
2016 CATERPILLAR...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
2022 RAM 2500 HEAVY DUTY (A55745)
2022 RAM 2500...
2004 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP (A58214)
2004 TRAVIS BODY &...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A61306)
1992 Talbert 70...
