Buying Advice Pat's Easy Change System
   / Pat's Easy Change System #1
hamhog
Want to know if this system will fit an old Ferguson TO-30 cat 1 hitch and will it work with stabilizer arms too?
Thanks,
Bruce
   / Pat's Easy Change System #2
I don't know if it would work with the stabilizers too but it should work without. I don't think it would work too good on that tractor because you don't really have a way to keep the lift arms from being to narrow or wide when you try to hook up to a implement. With the Pats you will proabably need a longer toplink and you will need to check your pto shaft length. I think a regualer quick hitch would be better if you quick hitch compatible implements or you could make them quick htich compatible, you will still need to check your pto shaft length.
Tractor Supply has a version of Pats easy change, if it would not work with the stabilizers they would probably let you return it.
2008 Saturn VUE SUV (A50324)
2008 Saturn VUE...
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
2016 John Deere 6130M (A50120)
2016 John Deere...
2012 Hyundai Sonata Sedan (A50324)
2012 Hyundai...
UNUSED FUTURE SKID STEER QUICK ATTACH LAND LEVELER (A51244)
UNUSED FUTURE SKID...
Quick Attach Post Hole Digger (A47384)
Quick Attach Post...
