Pat's Easy Change Pat's Easy Change System
   / Pat's Easy Change System #1
gadgetman
Richland, Georgia
Kubota M4900
Pat\'s Easy Change System
"No stupid questions, just dumb mistakes!"
As it is 1110 PM and raining, I can't go out and measure, so will the system fit on a M4900 Kubota? I ran off the specs and will try to measure tomorrow. The thickness of my arms (on the tractor /forums/images/graemlins/smile.gif) might be a problem.
I've looked at the other "quick connects" and several of my older implements have different spacing. This looks like the ideal solution.
Thanks in advance!
   / Pat's Easy Change System #2
Re: Pat\'s Easy Change System
i don't know off hand if it will fit your kubota,but, my mahindra 4500 has a cat 2 3ph,pat's ad on tbn and on their website, only lists a cat1..i called them 2/16/04 and they do sell a cat 2
   / Pat's Easy Change System #3
Dieseldoc.
This is new information to the board. For a long time now it has been discussed that PAT doesn’t offer a CAT II hitch. It must be really new. Did they happen to quote you a price for it?
Eric
   / Pat's Easy Change System #4
Pat DOES sell a Cat II system, they are approx. $10 more. At least at the Louisville show he was selling them for that difference.
Thanks for the replies so far. I went out and measured just now. Mine is 1 and 1/2 inches wide (at the ball) and 3 inches tall. I have at least 4" of straight arm. Although my M4900 is CAT II, all my implements are CAT I. If it would fit I was just going to use the same shims that I use on my attachments. Does anyone know if the inside width of the "easy change link" is 1 and 1/2 inches or better?
Pat's site says: "Fits lift arms 2-3 1/4" tall"
"Requires approximately 4" of straight arm."
Nothing about width, but it seems to be a standard even to the compacts.
I would rather have the hooks a CAT 1 size instead of CAT II. Then I wouldn't have to use shims on the implements.
Maybe I'll just order them and give them a try. I've got a 30 day guarantee.
Thanks everyone!
   / Pat's Easy Change System #6
Buy the Cat I hooks and use a bushing to reduce your Cat II balls down.
Thanks........
I'm getting ready to order them now. Will do another post later and let everyone know how they work on a "BIG" Tractor........
   / Pat's Easy Change System #8
the price on the pat's system cat2 is 199.00 + shipping
Thanks dieseldoc. I am going to order the Cat 1 set first. As I said in an earlier post, all the implements we have are set up Cat 1 (used to have a Ford 8N & 3000). I have to use the shims on all the implements now to hook up to my M4900. It is already hard enough getting everything lined up but the shims seem to make it even harder.
If they don't work, I'll probably go the Cat 2 route. As most of my problems are the lower arms, I think this system will work better (at least for me) than the other Quick Attach systems.
I'll let everyone know "the rest of the story" after I try them out.
   / Pat's Easy Change System #10
what system are you folks talking about??? i have a M4900 too and would sure like a quick connect system...the ole brushhog and other implements have put on weight over the years, and i have a rough time movin em around to get everything hooked up...even stoop to usin a pry bar sometimes...
heehaw
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2017 Ford F-650 Mason Dump Truck (A50323)
2017 Ford F-650...
New/Unused 20ft Farm Metal Driveway Gate (A48837)
New/Unused 20ft...
2014 VOLVO VHD DAYCAB (A50854)
2014 VOLVO VHD...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
Quick Attach Skid Steer Quick Claw Grapple Industrial Grapple Rake (A51039)
Quick Attach Skid...
