Pat's Easy Change pat's easy change
   / pat's easy change #1
ToJo
AL
Kubota L3400 FEL
pat\'s easy change
how many inches does the easy change add to the lifting arms? I am xconcerned that I may not have sufficient overlap in my PTO shaft to accomodate the easy change.
   / pat's easy change #2
Re: pat\'s easy change
3 or 4 inches I believe, my pto shaft was long enough that it wasn't a problem. Works good too, I like the Easy Change.
   / pat's easy change #3
The answer depends a whole lot on the size you're buying, AND the amount of extension available in the PTO shaft.
Assuming your L3400 is the intended recipient, Pat's Cat 1 will extend the reach of the lower lift arms roughly three inches. If your PTO shaft was cut to the right length in the first place, a 3" differential should not be problematic. By example, my Cat 2 Pat's added four inches, and I still have plenty of reach on my rotary cutter PTO shaft.
//greg//
2021 New Holland P2350 Air Cart  New, Tow-Between, Intellirate Control, Dual Tires (A48561)
2021 New Holland...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A48561)
Kubota 24in Quick...
2018 Rock Solid 8x28 Cargo Trailer  Generator & A/C, Work-Ready (A48561)
2018 Rock Solid...
AGT 3pt or SS Seeder (A47809)
AGT 3pt or SS...
2023 John Deere FC 15R (A47307)
2023 John Deere FC...
2025 Kivel 48in Forks and Frame Tractor Loader Attachment (A46683)
2025 Kivel 48in...
