Peanut Planting/Harvesting on Small Acreage with Compact Tractor
   / Peanut Planting/Harvesting on Small Acreage with Compact Tractor #1
perdurabo
I'd like to try my hand at planting a small peanut field (6-7 acres) to produce peanuts for hay, fertilizer and for personal oil pressing (not for resale, I don't intend to sell for a profit). However, it looks like just about all the equipment for peanut planting and harvesting I've seen is either large vastly expensive purpose built self-driven combine machinery or PTO driven but intended for 140HP+ large tractors. Obviously such equipment isn't worth it for such small acreage.
Are there any implements out there in the US market for planting and harvesting peanuts with a compact category I tractor (~34HP)? I see various implements for small tractors in the Indian and Chinese market where there are still a lot of small producers with smaller tractors, but here is the US all I can see are huge machines for large commercial outfits. The red tape and expense of importing this equipment to the US seems nowhere near worth it though. How did small time farmers plant and harvest peanuts 60-70 years ago when most tractors were small? Were there implements for this or did they still do most of the harvesting by hand with pickers?
I should note that I'm in no way interested in hiring someone else to plant/harvest for me or borrowing equipment. I'm only interested in doing this if I can purchase and keep the equipment myself affordably.
   / Peanut Planting/Harvesting on Small Acreage with Compact Tractor #2
I'm thinking you'd be able to find equipment to till, plant, tend, dig, and windrow peanuts that would fit your tractor fairly easy. Where you're gonna run into trouble is with combining. Searching around online, the smallest combines I find used are 4-row machines that are probably going to need at least 75hp to run. Unless you can find a really old model that had, or convert a newer one to have, it's own engine. Even then, that would be a chunk of weight for a little tractor to control.
1992 AMADAS 9297 Combines For Sale At TractorHouse.com
   / Peanut Planting/Harvesting on Small Acreage with Compact Tractor #3
I have a similar question, but not specific to peanuts. I have 10 acres of land that nobody wants to farm, Eastern Shore of Maryland - what to do with it?
I want a reasonable crop that would make good use of the land, but what? the county agent says maybe talk to the grape growers, but I don't particularly want to do that. What about hay? Seems pretty simple, and the equipment seems like not too bad. Sesame seeds? Maybe peanuts is the answer. Ideas?
UNUSED JCT SKID STEER QUICK ATTACH HAYSPEAR (A51244)
UNUSED JCT SKID...
E-Z Trail 500 bu Auger Wagon (A50514)
E-Z Trail 500 bu...
John Deere Disk Chisel (A50515)
John Deere Disk...
HOBBS MODEL-666 16' HAY RAKE (A51243)
HOBBS MODEL-666...
Hydraulic Power Unit S/A Towable Pump (A50322)
Hydraulic Power...
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
