perkins 1104-44t engine failure
   / perkins 1104-44t engine failure #1
underbrusher
Tallahassee Fl
asv pt100 gyrotrac cutter head, jd 5525,5105,5603,4720,5210,997,544e,ford 8340,3000
My perkins engine threw a rod with 860 hours on it. Perkins is not honoring its waranty. Wondered if anyone else is having trouble with this engine?
   / perkins 1104-44t engine failure #2
G'day odd for perkins not to honour a claim what is the engine in and how old?
Jon
   / perkins 1104-44t engine failure #3
I've been reading about serious issues with Chinese built Perkins engines. I'm no expert and what I've been reading may just be anti-chinese propaganda.
here's a link to a professional pilot site..U.s. Continental Engine Co. Sold To Chinese Interests. - PPRuNe Forums .. check out post #10 .. other info is available if you look around.
Get some similar stories and see if you have a hope getting any warranty help.
BTW: how old is this engine, and what's it in?
   / perkins 1104-44t engine failure #4
The 1104 series has not been the real "Perkins for several years now, who did you buy your tractor from, you may be able to get help from that dealer,if you self imported your out of luck.We can still get parts for this engine but you will have to buy them.Here is there contact information
Address:
Tianjin Beichen Hi-Tech Industrial Park (West of Jinwei Road ,Beichen District)
Tianjin, China
Code : 300402
Web Site :www.lovolengines.com
Tommy
Affordable Tractor Sales Co.
"Your Jinma Parts Superstore"
Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
   / perkins 1104-44t engine failure #5
If you bought the tractor from an authorized dealer, you may have a degree of recourse...even if the machine is out of warranty.
If you bought it used, you're probably SOL, unfortunately.
My perkins is in a asv pt100 forestry track loader. It has 860 hours on it and is less than 2 years old. Perkins is still refusing any warrenty. Hope my lawyer has better luck than I have. Let me know of any more failures that you have heard of.
   / perkins 1104-44t engine failure #7
Still in the warranty period doesn't mean automatically covered. What are their reasons for not covering the damage? A manufacturer denying coverage is usually due to one or more of the warranty exclusions coming into play.
Was the machine used within its specified design parameters? Were repairs and maintenance done as per the manufacturer's recommendations? Were recommended fluids and such used? Was the machine operated in an environment outside of its spec'd capability....such as on excessive inclines where the possibility of oil starvation could lead to damage?
There are lots of valid reasons for a company to deny coverage, so what exactly are they telling you?
   / perkins 1104-44t engine failure #8
hey underbrusher call me 843-230-8222 i might be able to help you
   / perkins 1104-44t engine failure #9
There was a string of failures in those brush machines a few years back, not sure which engine model though. Not enough cooling or something like that.
   / perkins 1104-44t engine failure #10
I am an ASV Tech. We have had alot of problems with Perkins especially in the 60 and 100 series. Rods, head gaskets ,turbos and injector pumps. Perkins is a pain to deal with as they try to wear you down and hope you go away. It's a problem for customers as ASV as no control over what Perkins does, it's like buying a new Chevy and the dealer tells you that they can't work on the engine if it's under warranty.
   / perkins 1104-44t engine failure #11
we have two with around 3300 hrs no problems and just bought a new one hopefully no issues
Glad the guy has had good luck with his two machines with 3300 hours. This is the fourth asv that I have owned and have been pleased until now but this new one is a real problem and perkins nor asv will step up.
   / perkins 1104-44t engine failure #13
You would think since your a loyal customer, ASV/Perkins would fix your engine under warrenty.
   / perkins 1104-44t engine failure #14
There are an almost infinate number of causes for a catastrophic engine failure, WARRANTY only applies to TWO: Manufacturing DEFECT or WORKMANSHIP, therefore if the failure does not fall into one of those two buckets, technicaly (and legally) it would not be covered regardless of the failure mode.
Now there are essentially two ways to handle a failure during the warranty period of a product: 1) You cover it unless there is obvious and apparent evidence that the failure was induced or 2) You hold fast to the Warranty policy and cover ONLY those failures that have been proven to be due to Material Defect or Workmanship.
If the manufacturer wants to use system #2, you need a lot of research to defend denials and must have accumulated a lot of data in support of those denials.
Other manufacturers simply say, if the failure is within the warranty period, it will be covered regardless except in extreme and obvious cases of neglect or abuse.
I KNOW which type manufacturer I would rather buy from.
I have read a lot of responses to my original post, most of the ones defending perkins/terex are probably posted by there pr guys who watch these forums and try to minimize problems people are having. I noticed that someone said to stay clear of anything with a perkins in it, I dont think that is right either. I have no less than 8 tractors and/or mulchers with perkins power. I have been a loyal customer of both asv/terex and perkins, that is why this problem has bothered me so much. This particular engine had problems, they should stand behind it instead of trying to blame everyone or everything else. I know that my little complaint and my little lawsuit will not hurt perkins in the end .But right is right and wrong is wrong. I havent tried to beat them out of anything or run them down about their products, it is however very likely to cause great hardship on my business and family if it doesnt put me out of business I will be lucky. I just wanted other hard working, honest people to know what they might be dealing with should they need support. If anyone else has any info that might help my case please share it. By the way I had to take my machine to their "authorized service center" which come to find out doesnt even have all of its acreadations from perkins yet, and perkins based there denial on a few pictures that the local guy sent to them via email. No one from perkins has even looked at my engine in person or at any of the parts. They just sat in an office somewhere and decided that my problem was not important enough to them to bother with. Its my livelyhood that they are dealing with though and I hope that someone will hear what I am saying.
   / perkins 1104-44t engine failure #16
There are an almost infinate number of causes for a catastrophic engine failure, WARRANTY only applies to TWO: Manufacturing DEFECT or WORKMANSHIP, therefore if the failure does not fall into one of those two buckets, technicaly (and legally) it would not be covered regardless of the failure mode..
If there was oil in the crankcase, it's 99.99% probably a defect in parts or assembly. The application is approved by Perkins, they should cowboy up and fix their crappy (lack of) quality.
Manufacturers that don't stand behind failures have made an economic decision that it is cheaper to screw over the customers than to fix a broad quality issue until forced by lawsuit.
   / perkins 1104-44t engine failure #17
I can assure you that I don't work for Perkins as a "PR guy". And even if I, (or anyone else) was, how can watching the forums "minimize problems people are having"? If my original post sounded skeptical, it's because no details have been posted. None. Add to that the fact that in 25+ years of working on equipment and dealing with warranty claims, I can assure you that 90+% of submitted warranty claims aren't warranty issues at all. On top of that, most of the time when a claim is made, the end-user has done so without even knowing what their warranty covers, nor what it excludes. Additionally, many owners never fill out and send in warranty registration cards, and/or change of ownership cards. What happens then, is that if the manufacturer issues an equipment update or service bulletin, the end-user doesn't get a notice. The update doesn't get done, and expensive repairs can result.
How about we start over again with some details/photos/etc.? ;)
That's a good one. Not talking about this situation, (because we have no details), but I've yet to see an operator experience a catastrophic engine failure due to a lack of engine oil that hasn't subsequently added some nice clean oil after the failure occurred in order to cover their tracks. (My favorite one was when a rod let go and went out the bottom of the pan. The operator added some nice clean oil, which then ended up on the ground right in the middle of the dirty black oil pool that was already there. It was as obvious as it would be if you poured some black paint on the floor, and them poured some white paint right in the middle of the puddle.)
Another common "it wasn't me" scenario occurs when someone runs a new piece of equipment out of fuel and can't get it re-started because they don't know how to bleed the system properly. If I get there and find the mysterious "won't run" condition to be due to empty fuel lines, filters, and pump, I always ask, (just for fun, mind you), if the equipment was run out of fuel, and some was added after the engine quit because there's obviously now at least 10 gallons in the tank.
If 10 guys ran out of fuel during the machine's use, I'd *guesstimate* that 2 or 3 would actually admit doing so.
:eek:
   / perkins 1104-44t engine failure #18
Yeah I'm afraid I have no connection to perkins either.
   / perkins 1104-44t engine failure #19
X3 and i agree with you brokenot have seen and dealt with the same over the last 25 odd years and still see it a couple of times a year
Jon
   / perkins 1104-44t engine failure #20
The neighbour of my brother sometimes repairs my car in evening hours, he is a well trained car mechanic, who used to work for an independent organisation that did tests and checkups for others: you can call them to check a used car you want to buy, but they are also called by Volkswagen to do independent tests in warranty cases.
Once he took an oil sample of a 2 year old Volkswagen engine which had bearing failures. It turned out the oil was sparkling fresh !!! Conclusion: the owner ignored the oil warning light, seized his engine, then put oil in it and then filed a warranty claim at his dealer...
2023 John Deere 333G for Parts (A61306)
2023 John Deere...
2012 FREIGHTLINER CASCADIC DBL SLEEPER ROAD TRACTO (A60430)
2012 FREIGHTLINER...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
10 Lug Wheels Full Set (A57453)
10 Lug Wheels Full...
2015 International TranStar 8600 T/A Day Cab Truck Tractor (A59230)
2015 International...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
