KeithInSpace
Veteran Member
Is it supposed to do that? Maybe the PHD was just trying to get home?
Was using it for the first time at a neighbor's house (we barter favors back and forth...they watch my dogs once in a while). I have a 9" auger bit. First 18" went pretty good, then it bit into something and just went STRAIGHT down like a drywall screw. The ground is a pretty heavy, red, compacted clay, but I had the drop rate of the 3PH choked WAY down on the dial. It was dropping perhaps 2" a minute at the bit. I was running about 1/3 throttle or a smidge more.
I tried lifting it out, but I couldn't get enough lift force on that long boom arm.
Through a bit of manual labor, I was able to remove the bit, but it wasn't too much fun.
Is this one of those freak things that happens once in a while? Or is something I need to be specifically aware of to avoid? There were no rocks obvious in the hole or in the spoils. The only thing was a small bit of half-petrified tree root matter, but they amounted to twigs that weren't over 1/2" in diameter. The area was a fill slope adjacent to his house.
Just trying to get a read on this so I can perhaps modify my method before doing more holes. It was no fun extracting that auger bit by hand.
