Photo of my 5065e
   / Photo of my 5065e #1
Rmd8136
Ft mill, sc
Deere 5065e MFWD
Here is a picture of my 5065e, with disc harrow and FEL. Just finished small food plot in creek bottom. I am new to tractors and really enjoy my new (June 2013) machine. 44 hours so far and no problems except replaced fuel filler neck which was rusting . image.jpgimage.jpg
   / Photo of my 5065e #2
Congratulations, very nice equipment.:thumbsup:
   / Photo of my 5065e #3
Very nice tractor you have there! I have a new 5075E, which of course looks just like yours does here.
Looks like you're already getting some good use of of it! :thumbsup:
   / Photo of my 5065e #4
I'm green with envy
congrats and enjoy
   / Photo of my 5065e #5
Nice machine!
   / Photo of my 5065e #6
Sweet. Good luck with food plots!
   / Photo of my 5065e #8
Nice. Looks like a new disc harrow too. What brand and size disc you go with? I just rebuilt a 8' 3 pt hitch unit with 20" blades on 9" spacing with a 4" frame. My 5303 pulls it well.
   / Photo of my 5065e
I got a Woods DMH 6, paid $1550. It weighs. 890 lbs and has 20 notched blades spaced 7.5 inches apart. It cuts a 6 foot path and had gang adjustment angles of 0, 7, 14 and 21 degrees. The frame is 3x 3 tube steel with pins that go the frame and adjust easily. I really like it but do not consider it heavy duty. For my soil , sandy loam and clay loam it it great. I really like the "Everything Attachments" construction except for the angle adjustment mechanism. It features a threaded rod with handle for infinite adjustment which drives thru a "nut " welded on top of main frame. It could be fine but the "pin thru tube steel" is a superior design. I would be interested to know if anyone had had any failures of that welded nut. Other than that issue ( which may be fine) that unit seems heavy duty. It is about 2200 vs the. 1550 I paid. I am a structural Engineer and if I knew that joint was. "Designed" vs just built as "this seems like a cool idea", I would buy that unit.
MISC PIPE WRENCHES (A53843)
MISC PIPE WRENCHES...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2021 JOHN DEERE 624P WHEEL LOADER (A52705)
2021 JOHN DEERE...
2021 Toyota Corolla LE Sedan (A53424)
2021 Toyota...
V.E. ENTERPRISES 500 BBL FRAC TANK (A53843)
V.E. ENTERPRISES...
