toolz_not_toyz
The big day is getting closer and I need some advice on trailering the PT. There is another recent thread that discusses this very same subject but my situation is a bit different. I don't own a towing-capable vehicle nor do I own a trailer or plan to buy one (since I would hardly ever use it). So I plan to rent and it looks like the best option (and perhaps one the only one around here) is Uhaul.
Having never rented from Uhaul before, I started by checking several of the local Uhaul places. Well, turns out that most of them are "licensees" for Uhaul and they basically don't keep too much of anything around and definitely don't rent out anything other than car trailers. Seems that these places are really just setup to handle one way pickups and dropoffs...which is Uhaul's cash cow. So I was directed to check with the great big Uhaul place about 40 minutes south of here. Stopped by there today to check things out.
Buf before I left I checked the Uhaul website and I more or less had in mind what might be appropriate. Here's my thinking... I'm picking up a 425 and maybe two pallets of attachments. They have a 6x12 trailer or a 5x9 trailer (both open trailers) that might work out. The thing is, the smaller trailer has a ramp while the other one does not. Here are the links:
6x12 open trailer
5x9 open trailer
The bigger trailer has a dual axle and an "automatic surge hydraulic brake." The brake system is not electronic. Instead, there's some spring mechansim that I guess will engage the brake if the trailer suddenly moves towards or away from the trailer (I assume it works both directions, I just know it's not electronic because I asked and quickly looked at it). The trailer is rated for 2640lbs.
The smaller trailer has no brakes, is single axle, but has that ramp. This trailer is rated for 1660lbs.
I'm leaning towards the small trailer because of the ramp. The strategy would be to back the PT onto the trailer since I figure the rear end is heavier than the front. But first I would use the forks to lift the implements into the truck. Oh yeah, I plan on renting a 14 foot truck to pull the trailer.
14 foot truck, towing vehicle
How heavy are the implements? I'm getting the 48" mower, tiller, 4n1, LB, minihoe, forks, Post Hole digger head and one auger. I imagine that some of these things (like the mower deck and the tiller) weigh quite a bit. I'm a little guy and heck, the 48" mower deck from my lawn tractor was a pain to move around on my own!
From the PT website I see that the 425 is 45" wide and under 90" in length (from the front wheels to the back). And it weighs less than 1400lbs. So I'm thinking this will fit on that 5x9 trailer if I put all of the attachments on the truck. Does this sound reasonable?
Also, other than the keys, will there be a manual stuck to the tractor? I'm planning on bringing gas and a battery jump starter pack just in case.
Checking progress on the shipment itself, it looks like this shipment is getting moved around a lot. It started on an Overnite truck, then may have been moved to an Overnite intermodal truck. Now it seems to be on a Tip intermodal truck. Wonder if there will be any paint left by the time it reaches me... /forums/images/graemlins/frown.gif
Picking stuff up from a freight terminal is new to me, hauling a trailer is new to me, so it's all going to be a bit of an adventure. I'm trying to remove as many of the surprises as possible.
6x12 open trailer
5x9 open trailer
