Pioneer Quick Coupling
   / Pioneer Quick Coupling #2
The sleeve on a Double action set can be pushed or pulled when connecting or disconnecting.
I went back and took them out of the package to try them out in the store last night. To me, the single action is easier to connect/disconnect. Maybe because that is what I am familar with and single action is cheaper.
   / Pioneer Quick Coupling #4
I have use the two way sleeves for a while, and it is much easier to pull the sleeve and pull the hose at the same time, verses one hand pulling the QD sleeve back, and you pushing the QD fwd. With the two way sleeve, I can do the connection with one hand.
The Quick attach hyd fittings on the back of the tractor use two way sleeves in case you pull away from an attachment after releasing the 3pt and forget the hyd couplers.
SafeWay Hydraulics - Accessories
2025 8ft Office Shipping Container (A44571)
2025 8ft Office...
2005 MACK GRANITE KILL TRUCK(INOPERABLE) (A45046)
2005 MACK GRANITE...
VOLVO DD130B DOUBLE DRUM ROLLER (A45046)
VOLVO DD130B...
2019 GARDENER DENVER 2500HP QUINTUPLEX FRAC PUMP (A45333)
2019 GARDENER...
2024 VALLEY PIONEER EM15 MINI EXCAVATOR (A45046)
2024 VALLEY...
2014 CS&P  BLENDER (A45333)
2014 CS&P BLENDER...
