Piston Bully
   / Piston Bully #1
Piperflyer
USA
Kubota3030HST
Looking how to change the dash readings from metric to english on a PB 100
   / Piston Bully #2
Unsure if it's the same in the PB10, on the PB600's the metric/imperial settings are accessed via the I-Command on the armrest or using the touch screen - just can't recall which menu/name it's under something like settings or set up......once changed the operating data is recorded on the memory in the chosen metric/imperial setting but then the recorded data (& previous stored data) can't I understand be reset retrospectively.
2001 Chevrolet Suburban SUV (A59231)
2001 Chevrolet...
Case DX25E Utility Tractor (A59814)
Case DX25E Utility...
1999 International 8000 Semi Truck (A59814)
1999 International...
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
2002 Chevrolet C8500 Flatbed - CAT 3126 Diesel - Eaton Fuller 8 plus 2 Transmission (A56438)
2002 Chevrolet...
2022 Dodge Ram 4500 Miller 8,000lbs Wrecker Tow Truck (A59230)
2022 Dodge Ram...
