planter plates
   / planter plates #1
deere755
Platinum Member
central Illinois near Lake Shelbyville
Case 2090 Massey Ferguson 4233 John Deere 4700
I have been planting plots and replant areas with a model 71 planter for 3 years now. This is the 1st year I ever bought brand new plates and man what a difference it makes in the way the planter spaces out the corn. It was bad about dropping doubles from time to time but not with the new plates. I think I will buy new plates for it next year if I still have the planter. Population was closer to what it should be also. I always had to back it off before but this year I had to bump it back up. Just thought I would pass this along for all the 71 owners.
   / planter plates #2
I could be wrong... but didn't they make steel plates at one time? Seems like they would not wear out like the plastic ones.
   / planter plates #3
Not to steal the tread, but, what those little clicker (I think there is supposed to be a spring in there somewhere) things in the bottom of the hopper supposed to do and how do you know if they are working or not on the Flex 71 planter. bjr
   / planter plates
I have some old steel plates. The only thing I don't like about them is they tend to rust. Not sure how big of a deal it is.
   / planter plates #5
The nylon (not plastic) plates have been around for 40 years. I know IH, JD and MF used them. I think mostly because of less friction and no rust. The spring "clickers" are to pop out any kernals or debris that gets stuck in the seed holes in the plate.
   / planter plates #6
Were the old plates properly sized to the seed?
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A52472)
2008 V.E...
2002 FREIGHTLINER FL80 FUEL TRANSPORTATION TRUCK (A52472)
2002 FREIGHTLINER...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A52748)
2019 New Holland...
2008 JOHN DEERE 270D LC EXCAVATOR (A51246)
2008 JOHN DEERE...
Fire Truck (A51692)
Fire Truck (A51692)
2014 KOMATSU PC490 LC-10 CRAWLER EXCAVATOR (A52576)
2014 KOMATSU PC490...
