planting timothy spreader setting??
   / planting timothy spreader setting?? #1
rilesdav
Bronze Member
MA
Branson 6530c and Kubota BX25D
Hello,
I am going to be planting timothy hay on 1 acre of area that was just cleared and prepared for seeding. I have an Earthway spreader and was told I need 18lbs of seed per acre. I did some calculations and determined I would be on setting #4. A setting of #4 barely has the holes open. Does anyone have any suggestions as to what I could mix the seed with as a carrier to allow me to use a higher setting and have the seed spread more easily.
Dave
   / planting timothy spreader setting?? #2
Sand? A starter fertilizer?
   / planting timothy spreader setting?? #3
Hello,
Dave
What ever setting, the book calls for, I always cut it in half and double cover. This way, I don't run out of seed before I get over the field. Ken Sweet
   / planting timothy spreader setting?? #4
Hello,
Dave
A push type spreader?
If that is the case you are going to want it going on pretty slow because an acre is a lot of area to cover with 18 pounds of seed.
Yes, push type spreader, a suggestion I got from the spreader company was limestone. Any thoughts?
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
2013 VOLVO VNL860 TANDEM AXLE SLEEPER (A51219)
2013 VOLVO VNL860...
Gravelly Pro-Turn 148 48in Zero Turn Mower (A48082)
Gravelly Pro-Turn...
2010 Dodge Grand Caravan SE Van (A50324)
2010 Dodge Grand...
2005 GEHL CTL70 TURBO SKID STEER (A51242)
2005 GEHL CTL70...
PALLET OF NITROGEN APPLICATOR PARTS (A51244)
PALLET OF NITROGEN...
