Please help John Deere 170 won't stay running
   / Please help John Deere 170 won't stay running #11
It's a bedeviling problem, for sure. I disassembled and cleaned the carb, changed the spark plug, replaced the fuel filter, all to no avail. Would suggest this- make sure there's NO water in the gas lines! That solved my problem for the short term. It started to occur again, and it became apparent that there was no fuel flow to the carb. I ended up removing the filter, and blowing out the line that went to the tank with compressed air, and the flow was back to normal. There must have been sludge in the tank that clogged the line. The only real fix is to remove the tank and clean it completely out though.
1996 JCB 506B Telehandler (A55218)
1996 JCB 506B...
2008 Hitachi PC228 (A47477)
2008 Hitachi PC228...
1993 Ford F-150 Pickup Truck (A52377)
1993 Ford F-150...
2005 Mitsubishi Lancer ES Sedan (A54815)
2005 Mitsubishi...
5TH WHEEL HITCH (A53843)
5TH WHEEL HITCH...
2012 OVERLAN KILL TRAILER (A53843)
2012 OVERLAN KILL...
