PLS HELP !!!! How to remove a stuck injector pump on a KE75 engine
   / PLS HELP !!!! How to remove a stuck injector pump on a KE75 engine #1
kenneth67
mitsubishi ke75
Hi All
I need to get my injector pump off my KE 75 diesel engine as its not working and I'm having a problem getting it off.
I un did injector pipes and removed the 4 bolts holding down the injector pump, I lined up the rack with the housing slot and pump should just lift out ???? but no it is stuck I can only get it about 15mm lift . I can rotate it 180 deg with abit of fiddling and turning the control arm back and forward but it is catching on something.
I would really appreciate some feed back as to if you have removed one of these injector pumps as to where I am going wrong.
I have read and been told by a mechanic there is a plate on the side that when removed enables you to disconnect throttle control arm but I can not see such a plate and I have looked very closely , I had a look at my neighbours 3 cylinder mitiubishi tractor and I can clearly see such a side plate but not on mine KE75
There must be a lot of you guys that know how to remove my injector pump and I would really appreciate some help as it is doing my head in.
ken:confused::confused::confused::confused::confused::confused::confused::confused::confused::confused:
2012 WESTERN STAR 4900 SB (A50854)
2012 WESTERN STAR...
2015 FONTAINE VELOCITY 102" X 48' STEP DECK TRL (A50459)
2015 FONTAINE...
19011 (A48082)
19011 (A48082)
THE ROOTSTER STUMP & ROOT PICKER (A51243)
THE ROOTSTER STUMP...
2013 Ford F-150 XLT - EcoBoost, Blown Engine, Good Parts Truck (A51039)
2013 Ford F-150...
LINDE H80D FORKLIFT (A50854)
LINDE H80D...
