plugging with a three point drum plugger,
   / plugging with a three point drum plugger, #1
Belews Creek
North Carolina
Kubota 3301
Does anyone back up with the three point drum
plugger? for like close to things or will it damage the unit?
   / plugging with a three point drum plugger, #2
If ...close... is important to you ...go for it...
Maybe you won't get as perfect plugs as in open yard, but there are bound to be compromises needed..
   / plugging with a three point drum plugger, #3
Could you raise the implement, back into where you want to start, lower the implement and plug away?
No clue on how the plugger is made and if stresses backing under load would damage something.
   / plugging with a three point drum plugger, #4
I seen a 3pt plugger in action at a local college of mine in action on a JD 4320 doing a baseball field. In some parts of the field, they were backing up to the fence with it in the ground then going forwards. Obviously not turning -- doing it straight.
2000 Kenworth T300 5 Axle Dump (A43476)
2000 Kenworth T300...
2012 Caterpillar 621H (A45336)
2012 Caterpillar...
2006 Jayco Trailer, VIN # 1UJCJ02R761SU0073 (A44391)
2006 Jayco...
58 Liberty P383LE41 Sewage Pumps (A45336)
58 Liberty...
2006 International SA525 Vac-Con V390LHA Combination Sewer Jetter Vacuum Truck (A46683)
2006 International...
CAT RM-300 (A47001)
CAT RM-300 (A47001)
