PNW update
   / PNW update #1
Pete Judd
Veteran Member
The Thin Gravy Ranch in The wet PNW
Yanmar 186d, JD 314
9 inches of snow on Tuesday, then another bunch to bring it to over 22 inches on the ground here. Now we have freezing rain, and it is taking down the forest around us. Just like the 4th July, as all the tree tops gave way from the weight of the freezing rain. Some times it sounds like guns going off. Have power back on, but don't know for how long, so thought I would get this on the board.
found out that aig tires on the ice don't work. and will have to work on getting the chains set up as well.
   / PNW update #2
Are you the Peter Judd who built a log home off 320th along Coal Creek back in the 90's?
   / PNW update #3
Sorry to hear that, we had an ice storm like that a couple of years ago and it ruined millions of trees, it was really sad to see. Dead pines are still falling on our paths and we are afraid to go in some areas when it is windy. We were without power in some places for about two weeks.
   / PNW update #5
Pete, you got it a lot worse then we did. 30 mi. SE of Portland at 1,200 ft elevation, we got 9+ inches of snow and Portland and the rest of the valley got a couple. We usually lose power 2 or 3 times a year but this year Asplund did a good job trimming the trees and the worst we had was a couple scares with the lights going off for a couple seconds. Lights flickered all evening, however. Then a warm rain with wind hit and there's flooding all over the central and northern Willamette Valley.
1200 ft long driveway was drivable the day it rained except we got plowed in and a tree snapped off by the mailbox, falling into the street. I'm recovering from an unsuccessful medical procedure and am really glad I could clear the snow by the street with the tractor. Tried to cut up the tree so I could move it out of the way of the mail gal and the chain came off with the first cut. I got the tree moved, though.
Rain and wind forecast for tonight.
   / PNW update
Trees still coming down, power on, but not for 300,000 others here but not in my area. Still a mess, rain now, flood will follow. Spent 5 hours out on the tractor today with the back blade and got the car out so the wife could go to work.
   / PNW update #7
We got around 10.5" on a higher hill here on Whidbey but none of the freezing rain. All the trees are clear of snow at this time so no damage there. The wind is supposed to increase though so I wouldn't be surprised if a few don't blow down with saturated soils.
I see they closed the Tacoma Narrows bridge today for about 8 hours due to ice falling and that had to leave a whole bunch of people stranded and not very happy!
   / PNW update
Rain has taken almost all the snow away now. Took Moon road out of Oakville to day to go to Olympia via Little Rock. Looked like a war zone. One lane because of all the trees down. At least a mile of power line down in spots. Tops of power poles broken off. It will keep the line men in overtime for some time to come.
Everything back to normal here at the homestead.
   / PNW update #9
One thing that has puzzled me for a long time and that is why more power lines are not underground?
My Grandparents farm is not in Washington... I remember they were always loosing power in the summer from lightening and in winter from sleet.
About 25 years ago the grid was updated and everything went underground... the power problems have all but disappeared.
My neighbors and myself almost all have our power underground in Olympia... doesn't seem to help because the main line running along the road is always getting taken out by trees.
   / PNW update #10
Cheaper to put them overhead, easier to fix when there is a problem. Also, it seemed like they were putting alot underground about the time aluminum wire was becoming popular and it did not take long to start having problems (connections corroding if I recall correctly)...
2019 Ford Transit 150 Cargo Van (A48081)
2019 Ford Transit...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2022 Case IH 8250 4WD Combine (A50657)
2022 Case IH 8250...
2008 CATERPILLAR 320D L (A50854)
2008 CATERPILLAR...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
2014 John Deere 6125R Utility Tractor with loader (A50657)
2014 John Deere...
