woodlandfarms
Super Member
- Joined
- Jul 31, 2006
- Messages
- 6,136
- Location
- Los Angeles / SW Washington
- Tractor
- PowerTrac 1850, Kubota RTV x900
So I have been getting quotes in our area. It is not turning out how I had hoped or planned....
Concrete prices are crazy high. And they are influencing my decisions....
Let me back up... What I wanted was a 100x100 x 16 or 18 high shop. Saddly my money printing machine is broken so I am now down to a 3000 sq ft space and the hope it will be under 60K all up at the end of the day. Secondly, I was looking for a modern design, something more than a square box with doors....
My results have been as follows and I would love peoples opinions on the opinions I have received.... Anything beyond the square / rectuangluar with a normal peaked roof seems to double the price, but I see no good reason why. Single slope, Offset slope, they all seem to cause a panick with the pole barn people and the metal people just add tremendous amounts to the costs.
So I backed up, said OK, heck with this. I will make it up in unique siding. Lets just make a normal structure shop cause I desperately need one.
Well the Pole barns are a bit less for the materials, not signifcant. Concrete appears to be 1/3 less but I get you basically have to make your monolith slab before you put the beams down. But labor is nearly twice as high. Each Pole barn quote was 30K for labor, where as my metal was around 15 max. Now maybe I am just at that breaking point where a metal building was more cost effective, but I honeslty thought it was in the 100X100 size before that happened.
I thought about trying to hire a hand and put the structure of a pole barn (not the sheeting) up myself, but my neighbor who used to erect pole barns says mine is too big for a couple of guys with limited knowledge.
So Why in the heck are doors and window OPENINGS so expensive?
Does anyone have an out of the box idea (from expereince) that would get me a modern looking building without sending designers into the 'it costs a lot" mode
Finally, and this is probably my biggest question. I plan on turning one of the bays (25X45) into a woodshop. This means erecting walls and putting a ceiling on. With the pole barn, the process looked pretty straight forward, but I do not know how it works in a metal building. Is it more expensive? more complicated? I am assuming you have to erect four walls, that you will not be able to use the exterior walls for support.
Anyway. look forward to all of your thoughts.
