woodchipper
- Joined
- May 17, 2011
- Messages
- 247
- Location
- Campbell's Bay, Qu饕ec, Canada
- Tractor
- 1965 JD 710; 2000 Universal 643DT 4wd, loader, cab with heat:), 1983 MF 50F Backhoe 2wd.
Pole construction census: 6"x6" PT post, VS: 3x 2"x6" PT glued/or not glued laminated
Hello builders of all kind!
I am in the planing stages(as are others...) of a Pole Barn construction. My particular build will be 24' wide x 60' long, with a pole spacing of 10' on center. In order to have something built strong and durable, the poles that we use are therefore somewhat critical in the construction process.
So, I am doing a sensus, for all of you who DID have previously built a Pole Barn. When did you erect your building(year), which pole method did you use, why did you chose such method, how well is it holding today, and if you would do it differently today, what would you do, and why?????
So thank you to our experienced builders who will take the time to share on this Specific subject.
