Poor Man's Front Weight
   / Poor Man's Front Weight #1
Aquaman
At the end of Smakadeer Rd. in WestCentral MO
Kubota BX24
If you have a FEL, you can just lay a 55gl plastic barrel in the bucket and fill with water. Just keep the bucket tilted back, and if you drive like I do, you may want to wrap a chain around it. Amount of weight is easily adjustable by adding/draining. Water weighs approx 8lbs. per gallon. You do the math. Sure helps keep the front end down when using the backhoe. Also makes a great bumper when things jump out in front of you!:D :D :D
   / Poor Man's Front Weight #2
If I would ever need front weight, I'd just go get a scoop of dirt... :D
Easy come, Easy go! ;)
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
71057 (A49346)
71057 (A49346)
SET OF HANG ON WHEEL LOADER FORKS (A51242)
SET OF HANG ON...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2019 GEHL RT105 SKID STEER (A51242)
2019 GEHL RT105...
