Portable Generators
   / Portable Generators #1
Pettrix
Platinum Member
High Desert Southwest
Looking to get a portable gas generator, around 8,000 - 10,000 watt generator output. This will be to operate the well water pump during construction and some power tools. It will later be used as a backup power in case the main electric power goes out.
Been looking at Generac and Honda.
Generac XP8000E (clean power design for sensitive electronic equipment) - $2,400
NorthStar Honda - $2,300
Any other ideas, comments or recommendations?
   / Portable Generators #2
I have a Generac 17,500 KW that works real well for me. I have an emergency panel (100A) that feeds all but the 240V loads. They are on sale often. Somebody (not sure who) just had them for $2600. I paid 2700 at Home Depot using my 10% military discount. My electronic stuff works just fine on it.
Ron
   / Portable Generators #3
I've always had Honda generators and they never have failed to start easily. Been here 34+ years and never had to use it during a power outage. I use the generator to run power tools when I'm out & about on the property.
We just happen to have an excellent electric co-op. Longest outage in 34 years has been 26 hours.
   / Portable Generators #5
Is the North Star/Honda a REAL Honda genset, OR is it a North Star generator head with a Honda motor??
To me, there is a difference.
SR
   / Portable Generators #6
It's a North Star generator head powered by a Honda engine, but you're right, while it may have a good engine, I seriously doubt the generator head would be as good a quality as a Honda manufactured one.
   / Portable Generators #7
We used a porter cable 5500 for years before it blew its' guts out (backside oil filler cap blew off & dumped all oil) a year or so back during an outage. We replaced it (same day) with a Champion 7000/9000 electric start dual fuel from Costco. Probably 30 - 50 hours on it so far & no problems (only run on gas so far, haven't done LP). During outages it has supported 1 freezer, 2 refrigerators, 1 fridge/freezer, well pump, heat pump water heater, micro-wave, coffee maker, overhead fans, TV/Dish/, computers, etc. It has been fine with the TrippLite UPS units we use (they see it as good power) and the wave form seen on a 'scope looks pretty clean to me. No problems for any equipment so far.
Regular price is $799, bought it while on sale ($200 off). Has the usual side connectors (one 240v 30A twist lock, 2 dual 120v GFCI outlets each w/20A breaker plus a 120v 30A L5-30R). Comes with a 25' 240v twist lock extension cord that terminates in 2 dual outlets, each with its own 20A circuit breaker, the hose/regulator needed for a propane tank connection, and a wall wart battery tender.
Nick
   / Portable Generators #8
We've had good luck with the DuroMax 10000Watt which often sells for < $700.
Sodo had a thread on it in Welding about a year ago.
If you can get three for the price of the ones you mentioned you would have two backups :)
   / Portable Generators #9
I can't remeber what I paid for mine its something like a 6500 running watts and 8000 surge. It was less than a $1000. Its not going to have the clean power a high quality one will have but do you really need clean power to run sensitive stuff?
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
2023 John Deere 8R410 MFWD Tractor (A52128)
2023 John Deere...
2020 Trailerman Trailer (A50514)
2020 Trailerman...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
