Post Hole Digger BX2200
   / Post Hole Digger BX2200 #1
RodneyV
I know there are several posts on PSD's for the BX2200's but I just need to know who has the most inexpensive one that will fit. Also curous if anyone sells a 6" auger that will fit? I need to install at least 100 2" steel posts for a rod iron fence.
   / Post Hole Digger BX2200 #2
Do you have a FEL? If so you can round up a helper and press the posts into the ground with your bucket.
   / Post Hole Digger BX2200 #3
I think the Northern Tool off the shelf unit will work with no problems.Maybe there is a cheaper one out there.Hope this helps you.
   / Post Hole Digger BX2200 #4
The unit from TSC has a 6" auger available. Mine works like a champ.
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2021 KUBOTA SVL 97-2 SKID STEER (A51242)
2021 KUBOTA SVL...
2018 John Deere 1445 72in Front Mower (A48082)
2018 John Deere...
SCAN FOR HAULING AND FINANCING INFORMATION (A51242)
SCAN FOR HAULING...
2020 Ford F-150 Crew Cab Pickup Truck (A50323)
2020 Ford F-150...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A52128)
2019 Energreen EVO...
