Posthole Digger Post hole digger versus post hole driver?
   / Post hole digger versus post hole driver? #1
Cormac
Park Springs, Texas
Before I decide an alternate approach, I am looking for some advice. I have access to a Rhino pneumatic post driver and can drive 2 7/8" pipe 3-5' into the ground. The soil is sandy with rock (Wise County, TX), so I think the 5' is do-able. I plan to make a pipe and cable (or sucker rod) fence. Will it hold up without concrete? I do not want a leaning fence over the next few years. Or, do I do the post hole digging and concrete route. Driving the fence would certainly save a lot of time, assure deeply placed pipe, and eliminate concerns with sandy soil cave-ins in the post hole drilling process. What do you think? BTW, I will have some cattle. Thanks to all.
   / Post hole digger versus post hole driver? #2
Drive 'em if you can. 3 feet deep ought to be plenty.
gabby
   / Post hole digger versus post hole driver? #3
driving is the way to go if you have the equipment to do it.
   / Post hole digger versus post hole driver? #4
You could still make various stays as needed if worried either way ?
   / Post hole digger versus post hole driver? #5
Driven posts will be more solid than holes filled with concrete. For what its worth I have clay soil with little rock and no sand, I do not have any issues with 4-10" wooden posts driven 3' deep in the wet weather or the frost heaving time of year on a high tensile fence which is known to uproot posts at dips and valleys.
   / Post hole digger versus post hole driver? #6
The way the posts are put in is more important than the size of the post, or in other words, the better the fit in the hold (i.e perfect when driven) means it should always be superior, but down here heaps of posts were done by hand and they are still there as strainers for a long time, many generations and still going.
CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A50458)
CATERPILLAR D8T...
2015 INTERNATIONAL PROSTAR 122 SLEEPER (A51219)
2015 INTERNATIONAL...
2012 MITSUBISHI FUSO SINGLE AXLE DUMP TRUCK (A51222)
2012 MITSUBISHI...
GENERAC MAGNUM LIGTH PLANT (A50854)
GENERAC MAGNUM...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
1977 Allis Chalmers 7060 Tractor (A50514)
1977 Allis...
