Post Hole Digger
   / Post Hole Digger #1
Soggy Bottom Outdoors
Brandenburg ky
2013 john deere 5075E and others
I bought a Farm Star PHD new and planed on using it on a 8N. To do so I needed to shorten/cut the pto shaft to give it a full range of motion. Well I traded the 8N to a MF and now the shaft is to short in the raised position. Where can I find a short peice of shaft tubing, a foot or so, to lengthen it back out. It's the "triangle" style which is called something else because a internet search came up blank. I thought I saw some at TSC/Orscheln but the last couple times I've checked they had none. Don't need a complete shaft half, just some tubing.
   / Post Hole Digger #2
Check the local tractor dealer. In most cases, they will carry the replacement tubing.
   / Post Hole Digger #5
Is there any way that you could keep and use the long auger? I bet you could find a way to work around the length issue and be glad that you have the extra length.
   / Post Hole Digger #6
This being an older thread I was just wondering if the problem had been resolved ??
my thought was a welding shop could add to the solid shaft instead of the tubing ??
just my 2 cents.
Mike
2018 DODGE RAM 3500 (A52472)
2018 DODGE RAM...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2017 FORD F-650 FLATBED DUALLY (A52472)
2017 FORD F-650...
Kubota BX2230D (A47384)
Kubota BX2230D...
Tiger Mowers 90in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 90in...
