Potato Harvesting
   / Potato Harvesting #1
N1ST
Enfield, CT
Kubota B7800
I'm looking for ideas on how to harvest potatos planted in a row. Last year I used a pitch fork and got lots of skewered potatos. I've got to come up with a better approach this year. I don't have thousands to spend on a harvester, and my potato plot is not large yet anyways. I have a 3 pt chisle tine cultivator - could that be used?
Newbie question: is a potato plow just for making the trench or for harvesting too?
   / Potato Harvesting #2
Potato Plow! AKA Middle Buster. That's what I used last year. Just went along the row and out popped the potatoes. Sure beat the heck out of the year before with using a hoe and fork. With 3 or 4 of us working it took several days that year. You can get a new one for less than $150. And I pulled it very carefully behind my 62hp tractor.
   / Potato Harvesting #3
I haven't tried using a middlebuster / potato plow for harvesting my potatoes yet, but may try that this year. I would test it first to make sure it went deeply enough quickly, but many folks use them, and claim good results. I have used a "potato hook" which has a handle :( but still spear some potatoes...... usually the best ones! :( This year I spaced my rows so I would have plenty of room to use a tractor. :)
   / Potato Harvesting
Thanks folks. It sounds like a very useful tool. This is what TSC has to say about it. Anyone know if the TSC one is a good value/good quality?
Solid steel shank. Forged lift pins. Heavy duty steel frame. 14" heat treated furrower. King Kutters middle busters have a solid shank and a complete welded heavy-duty frame with a standard 14" furrower. It fits all 3-point hitches with category 1 specifications. The middle buster is great for laying off rows, digging potatoes, pointing a ditch, general field preparation and many other farm, field and garden uses.
   / Potato Harvesting #5
Aah yes, I've dug potatoes by hand with a shovel or fork; lots of hard, slow work. The middle buster behind the tractor is the fast easy way and works great.
   / Potato Harvesting #6
Last year I was not in real great shape when it came to harvesting time. So I decided to try to harvest the potatoes with my FEL. Much to my surprise, it worked quite well. I would dig down, get a bucket load full of dirt, get off the tractor, take the taters out of the bucket and do it again. Took no time at all!
   / Potato Harvesting #7
You know, before I had my potatoe plow I thought that a rock bucket on the FEL would be great! The potatoes would stay in the bucket while the dirt would fall though.
New Land Honor 3'' Semi-Trash Water Pump (A53002)
New Land Honor 3''...
2020 PETERBILT 567 TRI-AXLE MID-ROOF SLEEPER (A52472)
2020 PETERBILT 567...
2016 TANKKO 130BBL VAC TRAILER (A52472)
2016 TANKKO 130BBL...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A52748)
2016 KBH...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2016 Ford Focus SE Sedan (A51694)
2016 Ford Focus SE...
