Pouring oil from a 5 gallon bucket
   / Pouring oil from a 5 gallon bucket #1
manitoba
jd 2550
Pouring oil from q bucket is annoying with that little pull out thing in the lid, yeah you can turn the bucket sideways and use a funnel. I have been using those flex spouts that come with the 10L jugs of DEF using a new clean new one they cross thread on to the bucket pretty good and make it just like pouring a gas can. Anyone have a better other than bucket pump and a hose?
   / Pouring oil from a 5 gallon bucket #2
When I pour from one I use a large funnel and hold the bucket so the spout is at the top. Pour at a volume that allows air to enter as the oil comes out.
BUT last time I changed hydraulic oil in my backhoe I used my diesel transfer pump to pump it out and in.
thanks, but does nobody make a thread on spout like def jugs, they thread on pretty well i was just hoping somebody knew of a flexible spout made for a bucket since the little pull out thingy on the buckets is threaded.
   / Pouring oil from a 5 gallon bucket #5
I think I got a thread on spout for a five gallon bucket at my case IH dealer. Turned out to be no so handy. I just pour from the top if that makes sense.
   / Pouring oil from a 5 gallon bucket #6
I think any kind of thread on funnel would block the air into the bucket. I guess you drill a hole in the bucket but then you risk contamination and I re use the buckets for waste oil.
   / Pouring oil from a 5 gallon bucket #7
My M6040 takes 16+ gallons of hydraulic fluid. I have a big flex nozzle funnel and turn the 5-gallon bucket on its side. By the time I get to the third 5-gallon bucket of new hydraulic fluid - it has become a real PITA.
This year I'm going to get one of those cordless drill oil transfer pumps.
Parkson 3000A Feed Mill (A50121)
Parkson 3000A Feed...
2025 Auto Darkening Welding Helmet (A50322)
2025 Auto...
2015 Ford F-450 Service Truck (A51692)
2015 Ford F-450...
Engine Hoist (A50121)
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A52576)
2018 KENWORTH T680...
2016 Kia Cadenza Sedan (A51694)
2016 Kia Cadenza...
