power beyond hydraulics
   / power beyond hydraulics #1
hotwired
east tn usa
Could some hydraulic guru explain what and how the term power beyond works have a five spool open center valve and do not understand the term,Thanks
   / power beyond hydraulics #2
Not a guru, but I'll take a stab. Power beyond means you send hydraulics from a port on your valve to another valve. Your valve may not have a power beyond port on it. If it does have a power beyond port, you may have to modify to let it provide power beyond. If you have any literature, it should say. Some manufacturers put info online. Prince is one.
   / power beyond hydraulics #3
Power beyond functionality is only required if your valve is NOT the last valve in the series hydraulic circuit. Note that the 3pt is normally the last valve in the circuit.
Basically what PB functionality does is to redirect high pressure flow from the outlet port to the PB port. This is normally accomplished with a sleeve in the valve. The outlet port then becomes the return to tank port where neutral pressure exhaust fluid from the work ports (cylinders) can make it back to the tank. This is done because dumping the neutral pressure exhaust fluid back into the high pressure flow stream may not be advisable in all situations.
In addition, the valve's relief (if so equipped) will also dump fluid into the return to tank port.
2013 FOREST RIVER WILDWOOD BUMPER PULL CAMPER (A50854)
2013 FOREST RIVER...
2023 Ram 4x4 Pickup Truck Bed (A49461)
2023 Ram 4x4...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
John Deere 2010 Loader Tractor (A50514)
John Deere 2010...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A51219)
2016 WESTERN STAR...
2024 John Deere 872GP Articulated Motor Grader (A49461)
2024 John Deere...
