power steering
   / power steering #1
n.o.yat
ponchatoula la.
2007 l 3400
i have a l3400 kubota. does anyone know if the power steering operates off the same hydrulics as the fel and 3 pt hitch. my steering seems to be hard.
   / power steering #2
Yes it does use the same hyd fluid as everything else is run off of.
   / power steering
i looked for a seperate p/s pump and did not see one. i will look again. btw thanks
   / power steering #5
There are several other posts about the inlet line on the hydraulic pump allowing air to get into the system. I am new to this forum and not sure how to link to them, but look under L3400 postings. I think in this model the power steering has prority over other hydraulic functions which means that the steering maybe the first to show signs of air in the system which maybe casuing the hard steering issue. The inlet line looks to be on the right side of the tractor by the brake pedal from other pictures gat are posted.
2803 (A50460)
2803 (A50460)
2003 FREIGHTLINER CLASSIC XL  SLEEPER (A52141)
2003 FREIGHTLINER...
2013 Nissan Rogue S SUV (A50324)
2013 Nissan Rogue...
Grove 4x4 Rough Terrain Hydraulic Crane (A51691)
Grove 4x4 Rough...
2002 International 4400 SBA 4x2 Flatbed Truck (A50323)
2002 International...
2015 Ford Econoline Van, VIN # 1FDWE3FL4FDA28220 (A51572)
2015 Ford...
